Anyone have a jackhammer? (serious)
Either one of those electric ones or something that can run on 20-25 CFM of air?
I have to tear up some walk/path way a few doors down to get to a leaking waterpipe, I might need it for a few days, depending on where the actual leak is.
I'm about dead broke for another few weeks and can't spring the coin to rent one right now...but happen to have a full tank of gas in the Honda to pick one up
Let me know I don't relish the thought of swinging a sledge right now.
Normally I hate to suggest the alternate manual method of concrete removal, because anything I can do with a machine is inherently more fun. But...
Dig the dirt away from the side of the walk, lift the slab with a long pry bar (6 ft or more) using a 4X4 as a fulcrum and smack the slab with a RBFH (10 lb double jack or more) where you want it to break. Then just remove the chunk and repeat as required. I actually found it less distructive to my back to do that and it doesn't p**s-off the neighbors with a bunch of noise!
I've got a line on one with a compressor, but the engine hasn't run in years. The guys going to check with the owner of the unit and see if he'll let me test out the hammer, if it works I'll probably buy I (just a bit more than a 2 day rental on one)...although I don't know what the heck I'll do with it when I'm finished.
Never could sell a tool
I've got a big aircompressor (deisel) with a Ford industrial engine, it used to run okay and puts out 100+ CFM, but a guy came over several years ago to "adjust" the compressor stuff, and it never worked the same...it's an older "RotoAir", and I never could find a manual for it.
But, found out today the guy on Yosemite is paying 250 a ton for scrap iron...looks liek I'll make a few bucks on Monday
