Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
1997 - 2003 F150 97-03 F-150, 97-99 F250LD, 7700 & 04 F-150 Heritage
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-24-2008, 04:07 PM
jstewart007 is starting off with a positive reputation.
Question 2000 f150 5.4L misfire?
I have a 2000 F150 5.4L 4X4 which is misfiring. The engine light came on with the codes PO171, PO174, and PO302. The first 2 codes are Banks 1 & 2 Running too Lean, and the 3rd code Misfiring on #2 cyclinder. I've replaced # 2 COP and checked # 2 sparkplug. Truck still runs rough, and codes out PO174 & PO302????? I also using starter fluid sprayed for vacuum leaks NONE. Please help me with this problem? Thanks Jim
  #2 (permalink)
Old 04-24-2008, 05:07 PM
KingRanchMan02's Avatar
KY KR lover
KingRanchMan02 is gaining momentum as a positive member of FTE. KingRanchMan02 is gaining momentum as a positive member of FTE.
How long has it been since the spark plugs have been changed? How many miles are on the truck?
__________________
John
aka KingRanchMan02
`02 F-150 King Ranch SuperCab
Charcoal Blue/Arizona Biege
5.4L 3.55 LS, 4x2
Diablosport Predator Programmer, K&N filter.
`08 Sable Premier
Merlot Metallic, Black leather
3.5L Duratec, 6 speed automatic
  #3 (permalink)
Old 05-12-2008, 09:31 PM
findian is starting off with a positive reputation.
replace your 02 sensors aswell, sounds like your misfiring fouled the sensors
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
