Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1980 - 1986 F100, F150 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 05-02-2008, 09:35 PM
E30tdf is starting off with a positive reputation.
Jim......You are the Man!!!! Thanks.....exactly what I needed!
  #17 (permalink)
Old 05-03-2008, 12:47 AM
Coneynew's Avatar
Coneynew is starting off with a positive reputation.
Well, good luck with all that - just let me know if you want me to get the dual pump brackets from the 87 carb's 460 in the salvage yard. Everything in the engine bay is still there , except the carb. The complete dual air pump set up is available if you want it, just let me know. I'll be at the "yard" again this weekend. Hope somthing works out for your situation!
__________________
"Trying to keep it simple..."
Current Fords:
1985 F-350 XLT Lariet 2x4 "Camper Special" 460 auto 146k
1986 F-250 HD 4X4 351W HO auto w/ Plow 33k
1997 Taurus GL 4dr 3.0 Vulcan 70k
Current Non-Fords:
2002 Volvo S-60T Turbo 59k
  #18 (permalink)
Old 05-03-2008, 10:16 AM
With the help of your photos Jim, I was able to find the lower bracket that provides the belt tensioning in my disorganized parts bin. I still have not found the upper bracket that mounts the fixed unit and the bypass valve, but it will not be hard to make a bracket for that if I need to. At least now I will recognize it if I run across it in the next day or two or next trip to the wrecking yard(s). I used to have a nearly photographic memory for such. The years have taken that away....:-). Thanks
  #19 (permalink)
Old 05-06-2008, 09:15 AM
My truck passed Emissions finally.
Thanks to everyone here on the forum that helped with advice and pictures. Coneynew is supplying me with an original bracket and some hardware to put the finishing touches on this job.
As usual, the guys on FTE have been great. Thanks!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
