ford 460 D9TE-AB - Ford Truck Enthusiasts Forums
ford 460 D9TE-AB
Old 04-24-2008, 04:13 AM
65HTgalaxie 65HTgalaxie is offline
65HTgalaxie is starting off with a positive reputation.
ford 460 D9TE-AB
So i just bought a 460 block # D9TE-AB
Head Castings #D3VE-A2A
intake manifold casting #D6VE-9425-A3A
Im not quite sure what year it is i think its a 79 it would be great if someone could help me with that.
I am looking to rebuild this engine.
i was wondering if anyone knew the availability of parts for this engine and good places to purchase them from
Thank you
Old 04-24-2008, 04:56 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Thank you
1971-1987 bare block casting numbers.
D1VE-6015-AB, AB1, AB2 = 1971 mid year 1979 (1971/74 429 ~ 1971/79 460) / This engine does not use a weighted spacer behind the harmonic balancer.
D9TE-6015-AB = midyear 1979 thru 1987 460 / This engine uses a weighted spacer behind the harmonc balancer.
The flexplates & harmonic balancers are specific to the two casting numbers.
Old 04-24-2008, 11:06 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
65HTgalaxie first and for most welcome to FTE.
Next Bill's info is always good but sometimes he gets a little carried away with to much info lol (no offense Bill) but to answer your question the casting numbers you posted indicate somewhere between 79 -86 for the most part. The block casting number you listed is for as Bill stated midyear 1979 and on (they used that block casting number until 97 when they stopped making the 460s). So what you have is an externally balance engine, most likely a 460 (they used the same block and heads on the industrial 429s built after 79 also but was only in medium duty trucks and industrial applications like pump motors and big gen sets)
As to availability of parts, you have a huge choice on anything you want to do with that motor from mild to wild, that block is what I prefer for strokers due to the cylinders being approx 3/16th" longer on the bottom, and even in 2 bolt configuration will handle more hp then 99% of the population needs or will even build. Case in point I am running a 528 using a D9TE block with factory 2 bolt caps at over 900hp NA.
Just let us know what you want to do and we can surely help ya out
Now I do have to correct Bill on one point, first off they are NOT balancers they are harmonic Dampeners. secondly they use the same one on both internal and external balanced engines it's the spacer behind them that is different (yes you MAY have a different part number but the actual dampener is the same and all of them are neutral balance it's the spacer that makes the external inbalance not the dampener, after market doesn't use different ones) example of this for you is ford motorsports they list M-6316-A460 for 72-97 same part number same dampener from ford for both internal and external engines.
Old 04-24-2008, 01:51 PM
Quote:
NO OFFENSE TAKEN.
429/460: PARTS CATALOG CALLS THEM DAMPERS, TOO.
BUT ALSO CALLS THEM BALANCERS FOR OTHER MODELS.
Secondly they use the same one on both internal and external balanced engines it's the spacer behind them that is different
1973/79 Ford Light Truck Parts Catalog sez:
6316-DAMPER ASSY-CRANKSHAFT
460
1973: D0OZ-6316-B
1974/79: D4VZ-6316-A .. Use without weighted spacer - Used to service block #D1VZ-AB.
1979: D9TZ-6316-C .. Use with weighted spacer - Used to service block #D9TE-AB.
(D9TZ-6316-C replaced D9TZ-6316-B)
1980/95: D9TZ-6316-C
1996/97: F5TZ-6312-CA
Too much info? I dunno about you, but if I was junkyard hunting for a damper, I'd like to know what fits what.
Old 04-24-2008, 02:03 PM
and like I said your book shows a bunch of part numbers but what you don't seem to realize is that if you check Hollander Interchange you find hey whats this they ALL interchange with each other, and whats this?Most other dampener companies INCLUDING FORD use the same part number (read above post that IS a valid ford motorsport part number) what you don't seem to be able to grasp is PARTS BOOKS ARE WRONG A LOT OF TIME, OR ARE MISLEADING. remember your books say there is only ONE oil pump used for either front or rear sump oil pans but you were proven WRONG about that. Parts books are great and have a lot of great info but they are not gospel, this is something you need to come to terms with. I went through this I don't know how many times when I worked at a dealership, parts guy would insist the book was right but when I had the CORRECT part in my hand it wouldn't look anything like what the part bood said. 98% you have great info, but the parts books are written by people and they are NOT mechanics they are people that read books, and frankly they make a lot of mistakes.
Edit to add, YES the part numbers used throughout the years were different and on some of the early ones they are different also because of either the way the pulley bolts on etc but NON of the ford 429/460 dampeners have the inbalance in them, they are ALL neutral balance. The early ones obviously because the engines were internal balance but the later ones because they used a hatched weighted spacer to provide that external balance.
Old 04-24-2008, 02:51 PM
Bill I just did a google search on D4VZ-6316-A part number and the funny thing is there was only 3 hits and they are all in YOUR posts, I called my local ford dealer and he says that part number doesn't exist (say may be a discontinued or superseded part number but shows nothing for it) and says ford doesn't give a part number EXCEPT the motorsport number for the early engines.
Old 04-24-2008, 11:01 PM
Well thank you guys for all the information.
Im looking to rebuild it pretty much
new intake manifold, cams, hopefully i can put zoomies on it and i have a 750 holley from the 390 thats in the engine now.
Does Edelbrock make good intake manifolds for the 460?
Old 04-24-2008, 11:53 PM
yes the edelbrock intakes work fine depending on application and cam you can get one to match most anything you want to do.
Old 04-30-2008, 02:14 AM
Do you know where i could get more information about this engine or engine mechanics in general? like some reading material?
Old 05-07-2008, 08:26 AM
385seriesHemi 385seriesHemi is offline
385seriesHemi is gaining momentum as a positive member of FTE.
If you wants specs there is Alldata or Mitchell online or a Chiltons or if you like Motors manuals get one of those. I suggest a chiltons or Motors grouping manual that includes the year you have and entails more than just specs. There are a few books out there that are on this engine but I have bought and found errors here n there, but nothins perfect. Shop around online or at Barnes & Nobel. This site will be wealthy with knowledge also.
Old 06-11-2008, 02:37 AM
SO im looking for a few things can any one help me?
Exhaust manifold
Light weight flywheel
Headers
Cylinder heads
Old 08-30-2008, 08:35 PM
fordscj fordscj is offline
fordscj is starting off with a positive reputation.
I also have this block and i was wondering if there was a special type of crank that i needed for it because i have a stock 70's model crank that will not work.
Old 08-30-2008, 09:20 PM
yes you either have to use the late model externally balanced crank or one of the after market stroker cranks available now.
The only other choice involves a LOT of clearencing usually on both the crank itself and on the block (and not really worth the effort.
Old 08-31-2008, 02:41 PM
do you know of any sites that my have the crank that i need for a 460
Old 09-02-2008, 08:25 AM
OldRed02 OldRed02 is offline
OldRed02 is starting off with a positive reputation.
Quote:
Try Summit.
Exhaust manifold
Headers
Cylinder heads
What do you want to do? What kind of power are you looking for?
I will sugest that you stay with the D3 heads. With machining I have read that they can handle a good amount of power. They are the same heads I am running on my 460, and hoping for 400 hp.
Next best thing is to pick up a set of D0VE heads.
Serious need for casting number help jgavac 1973 - 1979 F-100 & Larger F-Series Trucks 0 05-19-2011 08:42 PM
4U crank ina D9TE-AB block retro48/52 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 07-22-2008 11:08 AM
'79 460 compression ratio 65HTgalaxie Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 06-13-2008 08:44 PM
460 block casting numbers 460dragger Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 08-20-2007 10:42 PM
460 Block casting numbers ivanribic Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 11 01-24-2004 06:38 PM
Tags
1974, 460, 79, a3a, balancer, block, d3, d4vz6316a, d6ve, d9te, d9teab, fit, ford, heads, hp, late, model, oil
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
