Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-24-2008, 12:08 AM
FlashBurn123 is starting off with a positive reputation.
Side Window weather striping
Hello, I am restoring my 90 Bronco II. I have had no luck locating weatherstriping for the two curved, side windows. Any idea where I can find replacement striping for these windows?
Anyhelp would be greatly appreciated.
Thanks.
  #2 (permalink)
Old 04-24-2008, 10:49 PM
80351's Avatar
MD Chapter LDR
80351 has a very good reputation on FTE.80351 has a very good reputation on FTE.80351 has a very good reputation on FTE.
Thanks.
If you are refering to the 2 rear side windows that is not weahter strip it is actually plastic molding. Try LMCtruck dot com they having everything you will probably need.
You can also try NPD National Parts Depot.
There are actually a lot of places.
__________________
Dave MD Chapter Leader
Mid Atlantic
Intl.chapter memebr
89 Bronco 90 BII
03 Liberty
Join the Maryland Chapter click HERE
MIDATLANTIC REGIONAL ALL TRUCK NATIONALS CARLISLE,PA AUG 8-10 2008 INFO HERE!
  #3 (permalink)
Old 04-25-2008, 12:02 AM
tbolt 460's Avatar
tbolt 460 is starting off with a positive reputation.
anyone need the metal molding for the side windows??? off a 85 b2
__________________
88 BII(208,000mi still going) chop project
90 BII,2.9/C5/D44/9in
86 Ranger Xcab STX 4X4,D35,8.8,456's locked,4in lift
94 Xlporer sport
95 Ranger short bed 4X4 3.0 5spd
http://gearheads.ipbfree.com/index.php?s=&act=idx
  #4 (permalink)
Old 04-28-2008, 12:10 AM
HBYHRS87 is starting off with a positive reputation.
Hello,
Are you looking for the rubber part the window glass is mated to or weather stripping for between the glass and the truck body? Never seen replacements for the glass side but I used some of the small width rubber seal I got at Home Depot and a thin bead of glass sealant from Autozone. Worked great for me, no leaks with two winters on it now, one of those here in Alaska with -50F test!
__________________
85 BII/2.8/M1456/3.73 LS-Ugly but only $200.00
87 BII/2.9/A4LD/3.73 open-Normal daily driver
88 BII/2.9, blowing oil!/A4LD/4.10 LS/2 in body, 4in Susp lifts, motor currently out & being resurrected.
99 Silverado Z71 extend cab to tote my BII parts!
  #5 (permalink)
Old 04-30-2008, 09:35 PM
80351's Avatar
MD Chapter LDR
Forget the little rubber seal just a bead of silicon will do it.
__________________
Mid Atlantic
Intl.chapter memebr
89 Bronco 90 BII
03 Liberty
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
