Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Engine Swaps
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-23-2008, 11:37 PM
pcwb is starting off with a positive reputation.
460 carb w/ C-6 to 460 EFI w/ OD
I need help from a expert -
I have a '70 4x4 Crewcab that is going to get a fuel injected 460 with the OD trans from a 1995 F-250 van. I think this combo will get better MPG and work well here in Colorado with the major elevation changes. I have done lots of motor swaps on these older (pre emission trucks), but I have not messed with the wire harness from a newer motor with EFI. I have all the wiring and computer, ETC..
How hard is it to sort out the wires to fit the old trucks panel? Do I use only the part of the harness that applys to the motor/trans? The van had the O/drive button on a stalk, can I just use a toggle switch? What will I need to do about the fuel pump? Can I do an external pump or does it need to be an in tank pump? I have dual tanks now, is there a way to use one pump for both tanks?
I know this is a major project, just hoping to get enough tips to keep it from being a nightmare. I am sure someone has blazed this trail before, so any help, hints or heads up would be appreciated.
Thank you in advance for any help,
__________________
Paul
__________________
Paul
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-24-2008, 08:06 AM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Your biggest headache will be sorting out the wiring. The main things you need are the engine/tranny wiring and computer, but there will be a few other bits needed as well. The computer requires a speed input and this can come from either a tranny mounted VSS or the rearend RABS sensor.. depends upon the year. I think the later truck used the RABS sensor but I think the E4OD can be modified to add a speed sensor if not so equipped. Your OD switch idea will work, and you can use a frame mounted high pressure booster pump and keep the dual tanks. There may be a few other issues but if you have the donor vehicle right there it shouldn't be anything you can't solve.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
