Quote:
Originally Posted by RonM
I tapped the front plate of the compressor & that did the trick. My fan still only works on high but now I know where the resistor is to replace it . Thanks for the help lsrx101
Way Cool! I'm glad that is all it was. You will need to adjust the clutch gap or it will keep happening. Remove the center bolt on the clutch (8mm head), slip the clutch off (watch out for falling shims), remove a (or the only) shim and reinstall the clutch plate. The gap isn't critical, but you want under .015"-.020" or less without the clutch rubbing when disengaged. Usually removing one thick shim does the trick but if you can't adjust it with what is there, the dealer sells a shim kit for less than $10. If it takes more than 10 minutes to adjust the gap, you took a beer break in the middle.
To break the bolt loose, squeeze across the clutch and pulley with a big pair of channel locks. Make sure the bolt is tight when you reinstall it. Use a drop of LocTite if you have it.
