Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-23-2008, 08:03 PM
bigblueovalman is starting off with a positive reputation.
port work question
I have a 1986 351 HO engine and just bought some E7TE heads from Allied Motorspots. They are completely rebuilt with five angle valve job,new guides,springs, posilock valve seals and resurfaced. I want to grind out the thermactor bump to help the flow a little more. The engine is fairly stock with a Comp Cams Xtreme 4X4 grind 262deg- 270 deg 111deg lsa.
My question is about opening the exhaust ports up to match the gaskets or not. I've been told that these heads are a high velocity head and I don't know if I should open the exhaust ports up for fear of losing the velocity of the flow or not. Also thinking of a good set of Hooker full length headers.
Whatcha think?? Bud
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-23-2008, 10:50 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
What you want to do is remove the exhaust valve, grind the air injection hump flat, blend and smooth the bowl area behind the valve right up to the seat(carefully so as not to damage the valve job), and then open the port up smoothly to the gasket surface. You can almost completely ignore the floor of the port(besides smoothing obvious defects), concentrate on making the roof and walls a seemless flowing surface.
You can grind these ports right into the water jacket and still not have enough airflow for a 351, so you don't have to worry about making them too big, but don't get too crazy or you will find water, or more likely a pushrod hole.
__________________
Paul O
1990 F150 4x4 XLT Extended Cab (Currently undergoing a heart transplant)
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
