Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-23-2008, 08:38 PM
dragogt's Avatar
dragogt dragogt is offline
dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE. dragogt has a very good reputation on FTE.
Portals? the good, the bad, and ugly.
Since that other thread has gone to ____ I'll start a new one.
Portals Pros and Cons?
__________________
92 Isuzu Rodeo 5sp 4x4
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Aaron -STG's - Pirate Investigator
Quote:
Originally Posted by captain p4 View Post
If you can't tell if you have a body lift or not maybe you shouldn't be giving people advice in the offroad forum????
  #2 (permalink)
Old 04-23-2008, 08:43 PM
fishmanndotcom's Avatar
fishmanndotcom fishmanndotcom is offline
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
how about the different version? i want to know specifics about each one. i'd probably end up running a set one day if knew more about them
i have heard a lot of people doing good things with the 404's
-cutts-
__________________
My Google Photo Gallery
-96 F350 4x4 ZF5 CC/LB, 37" SSR's, D66 turbo, Stage-1's, Banks IC, 5" stacks, York OBA
-72 Bronco 302/NP435/D20/D60/10.25 welded F/R, full hydro, hydroboost, 39"iroks
  #3 (permalink)
Ryan50hrl's Avatar
Ryan50hrl Ryan50hrl is offline
Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE. Ryan50hrl has a great reputation on FTE.
great ground clearance, with minimal lift....torque multiplication......
but....expensive, more parts to break and oh...did i mention expensive?
__________________
2007 Lariat screw - White Sand Tri Coat - chrome package - Black leather captains chairs - sunroof - audiophile - 20" Mark LT wheels - Color Matched Door handles -
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
Needed: 2004-2008 OEM cat back for F-150 supercrew
  #4 (permalink)
Old 04-23-2008, 08:53 PM
dragogt's Avatar
Yeah, I new that they were extremely expensive but give us a run down on how they work. (for lack of a better word)
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #5 (permalink)
Old 04-23-2008, 09:00 PM
Portal axles are an offroad technology where the axle tube is above the center of the wheel hub. Compared to normal layout, this enables the vehicle to gain a higher ground clearance, as both the axle tube and differential casing are tucked up higher under the vehicle.
Due to the gear reduction at the wheel which lessens the torque on all the other drivetrain components, the size of the differential casing can be reduced to gain even more ground clearance. Additionally, all drivetrain elements, in particular the transfer gearbox and driveshafts can be built lighter. This can be of use in reducing the centre of gravity for a given ground clearance.
However, as it requires a heavier and more complex hub assembly, these systems can result in an increased unsprung weight and require robust axle control elements to give predictable handling. In addition, at higher speeds, the hub assembly can overheat.
http://upload.wikimedia.org/wikipedi...PortalAxle.svg
(taken from wikiperdia... Portal gear - Wikipedia, the free encyclopedia ).
this place will be able to help you on building or buying the right parts for a portal... Home
-cutts-
__________________
  #6 (permalink)
Old 04-23-2008, 09:05 PM
check out this.... http://unimogcentre.com/unimogprinc.html#portalaxle
gives a killer run down of the basics with some sweet visuals!
-cutts-
__________________
  #7 (permalink)
Old 04-23-2008, 09:06 PM
quadzjr's Avatar
quadzjr quadzjr is offline
just another Rockwell looser
quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE.
i'll get in the specifics tomarrow, ive got a physics exam tomarrow...
__________________
Nick
STG's Minions: Sergeant at Arms
The Rockwell/4-link/anything Badass Specialist!
Dont be a puss, RUN ROCKS!!!!
Quote:
Originally Posted by Ebay Assjack View Post
The truck was lifted with the custom frame as seen in pix. (the best way to lift a truck!!!)
My Build: 96' f150 4link 2.5 tons etc etc etc....
  #8 (permalink)
dragogt's Avatar
Thanks for the link but I don't read German.
I had an idea of how they work. and I have an old issue of Off Road & 4x4 where they talk about it, but they only devote like a paragraph to it.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #9 (permalink)
Old 04-23-2008, 10:31 PM
IB Adrian's Avatar
IB Adrian IB Adrian is offline
Administrator
2005 Ford Falcon
My Garage
IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation IB Adrian has a superb reputation
Its essentially (from what I understand... my ex-neighbours Land Rover ran Mog axles - pictured below, before he sold it - although I have never pulled them apart), a gear reduction in the hub, with a large inner teeth gear, and a small pinion on your driveshaft.
They all have to be fully floating.
They are a great design, as they put the final reduction right next to the wheel, meaning driveshafts only take a fraction of the load they take in a normal design (i.e. Mucho more hp and bigger wheels!)
Less suspension lift required for ground clearance, better driveshaft angles
Their only downside (IMHO) is the cost, and weight.
Portal axles are pretty popular here... predominately because unimogs are popular, and we don't have the cheap access to other strong off-road axles like you guys do with Rockwells. Oh, and we are the kind of idiots that enjoy throwing 20k down on a pair of axles.
The Mog ones are stronger (but this is relative... if you can break a portal axle, you are doing a good job), but the Volvo ones (out of the C303) are lighter, and better in size for most vehicles.
What specifically did you want to know about them?
  #10 (permalink)
Old 04-23-2008, 10:52 PM
dragogt's Avatar
Tks Guy's.
Fred I don't know much about them, so when they were mentioned in another thread I started asking questions, it was suggested I'd be better off with a new thread.
so I figured I'd ask and have people pool there Gray matter on the subject. What they know, what they've seen, and what they've read. Etc, Etc.
and like what Fishy asked, the different types with pros and cons of each.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #11 (permalink)
Old 04-23-2008, 10:57 PM
IB Adrian's Avatar
Administrator
2005 Ford Falcon
My Garage
Ok... I will call up my old neighbour, and see what info I can drag out of him (he used to run Mogs on his Defender... he runs Volvo's on his current Range Rover)
  #12 (permalink)
Old 04-23-2008, 11:09 PM
dragogt's Avatar
Sweeet, thanks Fred, you rock.
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
  #13 (permalink)
Old 04-23-2008, 11:11 PM
IB Adrian's Avatar
Administrator
2005 Ford Falcon
My Garage
No... I Mog
  #14 (permalink)
Old 04-23-2008, 11:45 PM
quadzjr's Avatar
Quote:
Originally Posted by FTE Fred View Post
No... I Mog
you dorkfish.......
__________________
Nick
  #15 (permalink)
Old 04-23-2008, 11:56 PM
dragogt's Avatar
Hey easy callin the admin names, Especially when he's being good to me. lol
__________________
87 F150 lwb
83 bronco
86 mustang gt t-top
83 mustang gt
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
