Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1967 - 1972 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1967 - 1972 F-100 And Larger F-Series Trucks Discuss the Bumpsides Ford Truck
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 04-23-2008, 06:56 PM
Bookman is starting off with a positive reputation.
$2000 alignment WHAT?
So the front tires have started wearing fast on the inside since I put knuckles in the front springs as an experiment to see how bad the springs were sacked out. So before I replace the springs I thouhgt for $59 I'd have an alignment done. The guy calls back right away and says I need king pins , springs , shocks , Gearbox , and R inner I-beam bushing and with labor that will be $1900- 2000.
So I knew about the box and the others but nothin was said about tie rods and as old as the truck probably all bushings are in need. The way it was put I shouldn't do the king pins too big of a job for the garage so the question now is to save some $$ how long do the nylon bushings last as apposed to the bronze because I guess they need to be fitted at a shop.
This is my daily driver and down time is key. OH yeah and the Ford dealer says the bushings are no longer available from FORD.
Help me clear the air I've got to get after this thing quickly. 2WD with disc brakes.
  #2 (permalink)
Old 04-23-2008, 09:49 PM
vinlin95 is starting off with a positive reputation.
2000 alignment
I'd like to make that kind of money in my shop. All parts are available at about any local parts store. May have to be ordered but available. I'm not to crazy about nylon bushings, you don't get near the life out of them. As far as metal bushings are concerned, any good machine shop should be able to press and ream them for you. After that, no harder than putting the other together. I would replace all the bushings while your in there. you should be able to go thru the whole frt end for around $800.00 including the box if you shop around. Let me know if you run into a bind, been doing frt end work for about 25 yrs.
  #3 (permalink)
Old 04-24-2008, 12:07 AM
jhooch's Avatar
jhooch is starting off with a positive reputation.
Go through Energy suspension for bushings, polyurethane will not rot and crack like rubber. Definitely use the metal bushings in the king pins. Just drop your pins and spindles at a machine shop to have fitted. As far as the gearbox goes, it can cause a wander for sure and may improve driveability but is not necessary to replace to perform an accurate front end alignment.
__________________
Jhooch
'05 Excursion Limited 4X4 6.0 Powerstroke
'77 Bronco 302, NP435
'76 F250 4X4 Crew 360, 4-sp (will be Powerstroke)
'66 F100 4X2 LB Custom Cab 428, C6
'66 F100 4X2 SWB Custom Cab, 352, 3sp.
'62 F100 4X2 LB Custom Cab Uni, 262, 4-sp
'64 Ford Galaxie 500 2dr HT
'63 Ford Galaxie 500 2dr HT
  #4 (permalink)
Dave Severson is gaining momentum as a positive member of FTE.
I think I'd probably just keep driving it, start replacing front end parts as time and budget permit. When you get all the bushings, king pins, shocks, etc. done track down your local dirt track racer buddy and borrow his caster camber gauge, check your caster and camber, then set the toe in. Nothing much easier to work on then these old bumpsides.....Lots of good books and manuals available that will take you through every task step by step with pictures. As Vin said, any competent machine shop can do the king pin bushing install and ream for you, after that it's just remove and replace worn parts...... Use the metal king pin bushings, I tried to cheap out and used the nylon one's on a buddy's '69....a year later we took it all back apart and put the good ones in.....
Find an old mechanic instead of a young parts replacer and he will be able to adjust your steering box correctly.... If it's beyond adjustment, they're easy to find used....
__________________
Anybody can restore a classic, takes a man to cut one up......
  #5 (permalink)
Old 04-24-2008, 08:27 AM
Is it a safe bet to use junk yard steering boxes? Also is there usually a local store to obtain urethane bushings or only specialty shops. Looking at springs everyone offers variable rate and HD springs but the HD are usually the cheaper spring. Is one a better choice over the other. I was told the price comes from demand from the customers that everyone wants the HD over the Vari rate.
  #6 (permalink)
Old 04-24-2008, 09:27 AM
qman is starting off with a positive reputation.
The bottom line is you don't NEED any of that stuff. An alignment shop probably can't align the front end without fixing the worn parts. How do you align things that won't stay in one place? So you only need the stuff if you don't want your tires to wear. Do like Dave says and fix things as time ane money permit.
__________________
92 F150 2wd 300 I6
72 F100 2WD 360 C6 PS
  #7 (permalink)
Old 04-24-2008, 09:32 AM
Freightrain's Avatar
Freightrain is starting off with a positive reputation.
If you can get the old pins out, you can install the new brass style, though you need to take the spindles to a local machine shop and have them honed to fit new pin. Not really any more work, just need another vehicle for a day or so. Everything else is basically the same in the overall job.
If you can find another steering box, and the adjuster nut on top isn't bottomed out yet, it might last a while. Might want to price a rebuilt unit?
__________________
1967 F100 352/4spd
1969 F100 428CJ/4 spd
and a few hot rod FORD cars too
64 Galaxie with blown 390 4 spd
64 Galaxie wagon with 428 5 spd
2006 UMTR POWERSHIFT
POINTS CHAMPION
  #8 (permalink)
Old 04-24-2008, 12:34 PM
go the hd springs. cost wise & ford was always a little weak on the frt springs. about any parts store should be able to get urethane bushings for you. my steering box thru napa was about 200 bucks exchange.
  #9 (permalink)
Old 05-06-2008, 11:13 PM
390428cjt's Avatar
390428cjt is starting off with a positive reputation.
Price is alittle high for that kind of work you can perform some of this your self have the king pins done at a shop
__________________
390428cjt
FORD IS THE MOUNTAIN THE ROCK FELL OFF OF
1972 F-250 Camper Special 396 C-6 Dana 60 4.10 lim.
1996 F-150 XLT 4X4 5.8 Heavy Duty Package
1982 escort 52k 2dr hatch
  #10 (permalink)
Old 05-08-2008, 03:28 PM
Danger_Dave's Avatar
Danger_Dave is starting off with a positive reputation.
i would tell the mechanic to F himself
__________________
69 F100 360 C6 3.23 9"
USN GWOT VETERAN
CVN72 2003-2008
  #11 (permalink)
Old 05-11-2008, 01:27 PM
blue68f100's Avatar
blue68f100 is starting off with a positive reputation.
I've used the nylon bushings. Like every one say they don't last near as long as the bronze. But you can install them with out any special tool/reamer (machine shop). I normally got 5+ years out of the nylon bushings, with routine lube. It normally takes less that 1 hr to change the kingpin bushings.
Just change the parts as you get funds. The kingpins and tierod ends will have the most impact. The bushings if gone (or soft) will cause the truck to wonder, so they are required for good handling.
You can set the toe end your self using a tape measure and a marker. Just measure front to back difference on the tires. Spin the tires and mark it all the way around. If you have the wheels jacked up, you will need to put back on ground and roll to get every thing to settle.
__________________
68 F100, mod 360, C6 Auto
  #12 (permalink)
Old 05-11-2008, 02:08 PM
80broncoman is starting off with a positive reputation.
since this is a daily driver, It might be easier to find a extra set of I Beams
and nuckles and do the pins and all that off the truck. This is of course depends on if you can find the parts to begin with.
If you are considering more moderen disc brakes this method might even make it simple to convert to disc braks if you havent already.
__________________
Real men don't wear Bowties
  #13 (permalink)
Old 05-15-2008, 01:20 AM
This trucks already has front disc original but the idea of finding donor parts might be a good thing.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
