C6? transmission problems
Old 05-26-2013, 02:25 AM
warrengg250's Avatar
warrengg250
warrengg250 is offline
imtrying to remove the tail sction on a c6 transmission out f a car and put the short section off my truck on
  #32
Old 05-26-2013, 02:30 AM
warrengg250
i have a c6 from acar iput in my truck hw do swap tailsecton frolng to short
  #33
Old 05-26-2013, 09:08 AM
Chevy_Eater's Avatar
Chevy_Eater
Chevy_Eater is offline
What?
  #34
Old 05-27-2013, 08:49 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
Ok I think I figured out what you are saying, you want to convert a long shaft c6 to a short shaft c6. To remove the tailshaft I think just about the entire trans has to come apart. And make double sure your bellhousings match. If you have a diesel sell that car trans and rebuild yours.
  #35
Old 01-10-2014, 06:27 AM
jayzeller79's Avatar
jayzeller79
jayzeller79 is offline
im having this same deal with my truck, rpm gets real high and then shift's really hard. has been like that sence i bought the truck. it also down shifts way to soon.. any advice?? thanks...
  #36
Old 01-10-2014, 10:40 PM
84-6.9L's Avatar
84-6.9L
84-6.9L is offline
Remove your kickdown rod (with the vrv it isn't needed mines been off for 3 years) and tip the vrv on the side of the injection pump a little at a time until you are satisfied. The VRV should need to tilt towards the front of the truck.
  #37
Old 07-19-2014, 10:18 AM
Mike Ritter's Avatar
Mike Ritter
Mike Ritter is offline
Have 85 f250 4wd 6.9,putt 4'' lift on it other day now trans,shudders when taking off and feels like im pulling heavy load trans was rebuilt maybe 5000 miles ago,fluid looks good,has always shifted hard, thoughts?
  #38
Old 09-02-2014, 08:04 PM
Howard57's Avatar
Howard57
Howard57 is offline
Mine is '83 F250 6.9. I too have developed the shift into/outof 3rd at 45mph problem.
After reading the first page of this I checked and found:
My pump is maintaining 20+ Hg.
The top port of the VRV holds 0 Hg. So I guess it's hosed.
I have broken one of the VRV adjustment clamping screws and can't get the other to budge. Steel screw in white metal and apparently no anti-seize. Have PB Blaster-ed it a few times over the last few of months. I guess I could go ahead and put some heat on it to break the screw loose and not worry abut melting the VRV if I am going to replace it anyhow,
Is there other plastic that could be damaged back in there?
Also - I had an idea and just connected the vacuum supply to the trans modulator line and I get good shifting!
Why does this work?
Will the 20 Hg ruin the modulator?
old german
01-01-2017 03:26 PM
bsraborn
01-30-2016 04:02 PM
Dr. Johnson
11-14-2015 08:14 AM
406angler
03-03-2014 04:49 PM
Quick Reply: C6? transmission problems
