C6? transmission problems - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-26-2013, 02:25 AM
warrengg250 warrengg250 is offline
warrengg250 is starting off with a positive reputation.
imtrying to remove the tail sction on a c6 transmission out f a car and put the short section off my truck on
  #32
Old 05-26-2013, 02:30 AM
i have a c6 from acar iput in my truck hw do swap tailsecton frolng to short
  #33
Old 05-26-2013, 09:08 AM
Chevy_Eater's Avatar
Chevy_Eater Chevy_Eater is offline
Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.Chevy_Eater has a very good reputation on FTE.
What?
  #34
Old 05-27-2013, 08:49 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
Ok I think I figured out what you are saying, you want to convert a long shaft c6 to a short shaft c6. To remove the tailshaft I think just about the entire trans has to come apart. And make double sure your bellhousings match. If you have a diesel sell that car trans and rebuild yours.
  #35
Old 01-10-2014, 06:27 AM
jayzeller79's Avatar
jayzeller79 jayzeller79 is offline
jayzeller79 is starting off with a positive reputation.
im having this same deal with my truck, rpm gets real high and then shift's really hard. has been like that sence i bought the truck. it also down shifts way to soon.. any advice?? thanks...
  #36
Old 01-10-2014, 10:40 PM
84-6.9L's Avatar
Remove your kickdown rod (with the vrv it isn't needed mines been off for 3 years) and tip the vrv on the side of the injection pump a little at a time until you are satisfied. The VRV should need to tilt towards the front of the truck.
  #37
Old 07-19-2014, 10:18 AM
Mike Ritter Mike Ritter is offline
Mike Ritter is starting off with a positive reputation.
Have 85 f250 4wd 6.9,putt 4'' lift on it other day now trans,shudders when taking off and feels like im pulling heavy load trans was rebuilt maybe 5000 miles ago,fluid looks good,has always shifted hard, thoughts?
  #38
Old 09-02-2014, 08:04 PM
Howard57 Howard57 is offline
Howard57 is starting off with a positive reputation.
Mine is '83 F250 6.9. I too have developed the shift into/outof 3rd at 45mph problem.
After reading the first page of this I checked and found:
My pump is maintaining 20+ Hg.
The top port of the VRV holds 0 Hg. So I guess it's hosed.
I have broken one of the VRV adjustment clamping screws and can't get the other to budge. Steel screw in white metal and apparently no anti-seize. Have PB Blaster-ed it a few times over the last few of months. I guess I could go ahead and put some heat on it to break the screw loose and not worry abut melting the VRV if I am going to replace it anyhow,
Is there other plastic that could be damaged back in there?
Also - I had an idea and just connected the vacuum supply to the trans modulator line and I get good shifting!
Why does this work?
Will the 20 Hg ruin the modulator?
TCI C4 Transmission Issues bsraborn 1973 - 1979 F-100 & Larger F-Series Trucks 3 01-30-2016 04:02 PM
C6 TRANSMISSION WON'T SHIFT OUT OF 1ST Dr. Johnson 1987 - 1996 F150 & Larger F-Series Trucks 1 11-14-2015 08:14 AM
C6 changes shift points 406angler 1973 - 1979 F-100 & Larger F-Series Trucks 7 03-03-2014 04:49 PM
Transmission issue - slipping - gear - won't shift - vacuum modulator -Ross- 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-20-2013 03:33 PM
C6 won't upshift after rebuild mwistrom Clutch, Transmission, Differential, Axle & Transfer Case 4 08-26-2009 07:23 PM
Tags
adjust, c6, diesel, ford, modulator, noise, overheat, problems, questions, shift, shudder, transmission, transmissions, vacuum, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
