351 engine, 302 firing order? - Ford Truck Enthusiasts Forums
Old 01-05-2002, 06:20 PM
georgiafordman78 georgiafordman78 is offline
georgiafordman78 is starting off with a positive reputation.
I've positively identified my 78 f250s engine as a 351w. It has the taller deck, so i know its a 351 windsor. I thought it was a 302 for about a year now, but i was wrong. I'm confused though!!! It runs on a 302 firing order!! Why is this? Does it have a 302 camshaft in it? Or is it possible for a 351W to run on a 302 firing order. I find this a little confusing. It seems to have a 351W electronic ignition distributer, because it has the large 2 piece cap. Can anyone explain what the heck is up with my motor?
"Don't Laugh At This Truck Mister, Your Daughter Might Be In Here!!"
'78 F250 4x4/351/NP435/NP205
lifted/"35 mudders
'78 F100 2wd/360/C-6/"9 inch
4bbl int+carb
Old 01-05-2002, 07:29 PM
rc351w rc351w is offline
rc351w is starting off with a positive reputation.
If it's a windsor and has a 302 firing order then someone has put a 302 cam in it.
RCC
Old 01-05-2002, 08:01 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
302 and 351w distributors look the same on top.
Old 01-06-2002, 05:19 PM
THANKS!!!! One more question. If I'm not mistaken a 302 head is a 5 bolt pattern for the valve cover, and 6 for the 351. Assuming this, this means my motor has a 302 heads, and a 302 cam. What would this make my motor? Is this a bad thing? The engine has quite a good bit of power, spinning my 35 inch mudders with easy. I'm no dumby with engines, but I've never really got into "cross-breeding" them like this engine appears to be. Any info would be vert helpful...THANKS AGAIN...
lifted/"35 mudders
4bbl int+carb
Old 01-06-2002, 05:23 PM
I'm sorry, i was mistaken...my heads have 6 valve cover bolts. So its a 351w with just a 302 cam
i guess
'78 F250 4x4/302/NP435/NP205
lifted/"35 mudders
4bbl int+carb
Old 01-07-2002, 12:31 AM
airharley's Avatar
airharley airharley is offline
airharley is gaining momentum as a positive member of FTE.
Actually it's a blessing in disguise. 302 cams are cheaper.
Old 01-07-2002, 08:07 PM
Wouldn't I get more power with the 351w cam. It should have a larger lift and duration. Seems to me the 302 cam would just "de-tune" a 351w.
'78 F250 4x4/351w/NP435/NP205
lifted/"35 mudders
4bbl int+carb
Old 01-07-2002, 08:28 PM
Franklin2's Avatar
Both 351w and 302 have 6 bolts on the valve cover. After 1977, 302 heads and 351w heads are virtually the same except for the size of the head bolt holes. 351c/351m/400 have 8 bolts holding the valve cover on.
Old 01-08-2002, 01:08 AM
slimersoup slimersoup is offline
slimersoup is starting off with a positive reputation.
Should make no difference which engine the cam is designed for, the 302 will simply make power at a higher RPM range with the same camshaft than the 351. There is a much bigger selection of 302 cams out there, and they do tend to be cheaper due to the higher volume. I doubt that the previous owner installed a stock profile 302 cam in your motor, rather pointless.
Old 01-09-2002, 08:43 PM
Your right....it is a slightly larger than stock cam. It has that beautiful "lobing" sound to it. If I go back to a 351w cam, will I need to change distributers, or just swap the firing order?
lifted/"35 mudders
4bbl int+carb
Old 01-09-2002, 10:18 PM
slikness's Avatar
slikness slikness is offline
slikness is starting off with a positive reputation.
Just swap the fining order.
Old 01-10-2002, 10:02 PM
canadianfordman canadianfordman is offline
canadianfordman is starting off with a positive reputation.
I have the same 351w with a 302 firing order. My truck has an RV cam on it which the previous owner installed. Would there be anything else on my engine that is of 302 status? Thanks.
Old 01-10-2002, 10:13 PM
Old 10-01-2006, 10:09 PM
quinnman quinnman is offline
quinnman is starting off with a positive reputation.
351w marine engine
I am trying to determine the year of a motor. This 351w motor in is a 1977 wellcraft V20, but is not the original engine. The engine has points and condensor in it. Can anyone tell me what year ford converted to electronic ignition and how much trouble is it to convert to the newer electronic ignition.
quinnman
Old 10-02-2006, 07:45 PM
Jay5oh Jay5oh is offline
Jay5oh is starting off with a positive reputation.
The 351W firing order is the same as the 302 "HO".
Engine Confusion mrbillsadventures 1967 - 1972 F-100 & Larger F-Series Trucks 9 11-02-2016 08:13 PM
NOT YOUR AVERAGE FIRING ORDER? Scotty150custom 1973 - 1979 F-100 & Larger F-Series Trucks 13 03-30-2016 02:20 PM
302 351w oilpan ? bigfoot7180 1973 - 1979 F-100 & Larger F-Series Trucks 3 02-13-2011 01:43 PM
351w motor mount ?'S willys_gasser 1961 - 1966 F-100 & Larger F-Series Trucks 9 06-17-2008 06:19 AM
couple problems after F4TE cam install mvvette97 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 09-19-2007 03:07 PM
Tags
1977, 1984, 2001, 302, 351, 58, engine, f150xlt, f250, firing, ford, lightning, motor, order, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
