my wmo filter setup- your thoughts - Page 5 - Ford Truck Enthusiasts Forums
  #61
Old 12-16-2010, 07:01 PM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
Subscribing. Any updates?
  #62
Old 01-02-2011, 12:12 PM
ditch witch ditch witch is offline
ditch witch is starting off with a positive reputation.
I've been using filter WMO since my last post here in the 6.9 without any problems. I've been mixing according to the time of year. Summer days with 80 deg and up temp. I mix 75 oil-25 diesel and as it cools off in the fall I reduce the amount of oil.
  #63
Old 01-02-2011, 12:19 PM
1967 Turbo 6.9 1967 Turbo 6.9 is offline
1967 Turbo 6.9 is starting off with a positive reputation.
How small are You filtering it to?
  #64
Old 01-02-2011, 12:29 PM
Go back to post #58. I'm using a "triple stacker" Frantz and it then goes into a single Frantz and then ready to burn. How small it filters to..... I don't know. But it works well and easy to build. I had all the parts except the pump which cost $40.
  #65
Old 01-05-2011, 01:11 PM
catbird7 catbird7 is offline
catbird7 is starting off with a positive reputation.
I just completed another 5000 driving miles of hunting season, running a 50 / 50 mix of wmo & Fuel. I used the word "Fuel" because I'll mix it with Kerosine, Home Heating Oil, or Reg. Diesel. The filtering method is very cheap any easy! I simply gravity feed it through a coffee filter. Been doing this for years with no ill effects. Gas mileage drops from around 20mpg to 17mpg with a noticable difference in power. The engine is noticably quieter.
  #66
Old 01-05-2011, 02:14 PM
Quote:
"A noticeable difference in power" in which direction? More power or less?" What outdoor temperatures you looking at?
  #67
Old 01-05-2011, 02:17 PM
Noticeably "less" power when running the mixture.
  #68
Old 01-05-2011, 02:23 PM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Have you done a Blackstone oil analysis on the waste oil your using?
You should. Then post the results here. You would be amazed at what your running through your injectors............
  #69
Old 01-05-2011, 02:50 PM
Speaking for myself, "what's in the oil" doesn't worry me enough to care! It's like scooping up a jar of air, sending it off for analysis so you can worry about what you breathed even though you feel fine. Like I've said in previous posts, if Cummins does this to brand new engines, I'm sure it won't hurt my old beater! My old truck has 280 thousand something miles on it, at least 20,000 of the last 50,000 miles I used some mixture of WMO with no ill effects. Ask yourself (you don't need to answer me) with that information, would you be interested in paying for an oil analysis report from anyone and even if you had one would you believe it if it said bad things will happen?
  #70
Old 01-05-2011, 03:36 PM
Nothing personal. I don't care what you run in YOUR diesel. Other people that read these threads could get the wrong impression that WMO is totally harmless. Especially when you start talking newer diesels that use injection pressures above 25,000 psi.
The following link is to a blackstone report for a Cat diesel engine that I posted 2 years ago in this same thread: Diesel Engine Sample Report 1
Pay particular attention to the Aluminum, Zinc, Iron, Boron, Calcium, and Phosphorus levels in the 3rd column from the left.
This does not even take the other chemical products of combustion. WMO from gasoline engines is even worse!
A lot of people wanting to save money will read threads like this. I just want to make sure they get ALL the info.
  #71
Old 01-05-2011, 04:04 PM
I agree that if I were considering using WMO in a $40,000.00 truck, it would be completely decision!
  #72
Old 07-13-2014, 09:55 PM
86f350's Avatar
86f350 86f350 is offline
86f350 is starting off with a positive reputation.
Holy old thread.....Any updates ?
  #73
Old 07-14-2014, 05:48 PM
Still have the same truck, with the same engine, running the same fuel mixture, no problems. The only thing I've done since the last reply (3 years ago) was add a factory ATS turbo. Yes, I know many people think this is also a no, no, for a 303,000 mile engine with no studs in the heads however so far (knock on wood) it works great. Injection pump turned up two flats. Huge increase in power! I also had Conestoga Diesel set the timing properly.
Mixing fuel has become a little easier than my "coffee filter days". Now I save used motor oil, trans fluid, hydraulic fluid, basically any oil, in 55 gal drums. Let it set inside the unheated garage till January. Then pump it out with a small 12volt dc fuel pump (Holley Red) and push it through two wool oil furnace filters and then finally through a 5micron fuel filter. The oil discharges into a 275 gal oil tank which I've preloaded with 140 gals of home heating oil purchased during the summer months when it's cheapest. I do this in January because all of the water will be in the bottom of the barrel frozen. I also keep the pick-up hose approximately 4" off the bottom to avoid everything that settles including antifreeze. Continue adding filtered oil till the 275 gal tank is full which results in a 50 / 50 mix. Then let the pump run for a couple days in a "loop mode" where the fuel mixture comes out of the bottom of the 275 tank and enters into the top. This makes sure everything is well mixed. I've also played around with gasoline mixing it 85% used motor oil to 15% regular gasoline and it seems to work fine however I'm sticking with the current 50 / 50 mix because I know it works. Again, if I had a $40,000.00 or $50,000.00 truck, I wouldn't think of doing this, however the old IDI diesels will drink this stuff and not complain!
  #74
Old 07-28-2014, 09:04 PM
Marianna2003 Marianna2003 is offline
Marianna2003 is gaining momentum as a positive member of FTE.
Thanks for the info Catbird7. I'm planning to run @50%WMO 30%D2, and 20%Distilled Water. Lubrizol has a product called Purinox that they mix 20%water with a proprietary emulsifier and D2. WMO is an excellent emulsifier that's what makes it a detergent oil. After reading some of the posts here, I may eliminate the D2. As far as the pictures of the injector from a powerstroke, it's a direct injection engine, IDI means indirect injection and uses a prechamber to create extreme turbulence to improve combustion. This same turbulence should keep our tips clean. :-)
  #75
Old 11-28-2014, 10:46 PM
idahoFORD350 idahoFORD350 is offline
idahoFORD350 is starting off with a positive reputation.
Thanx man I was pleased to hear someone say that (first couple of sentences, nice anology )
WMO/clean unused oil ... d-day Bio-diesel, Propane & Alternative Diesel Engine Fuels 33 06-06-2016 10:14 PM
WMO ghunt Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 12-28-2009 07:56 PM
Diesel fuel lubricity additive study, 2 IDPisan 1999 - 2003 7.3L Power Stroke Diesel 17 09-11-2007 11:02 AM
filters and wvo 14psd Bio-diesel, Propane & Alternative Diesel Engine Fuels 2 07-02-2006 01:22 AM
Ok I got an issue, problem, question whatever on the prepump line mod monsterbaby 1999 - 2003 7.3L Power Stroke Diesel 50 03-25-2006 02:11 AM
Tags
bag, biodiesel, carbon, detroit, diesel, fill, filter, fitlering, frantz, fuel, injectors, rite, set, setup, truck, wmo
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
