Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #31 (permalink)
Old 05-15-2008, 03:02 PM
travisg96 is starting off with a positive reputation.
As far as WMO goes I can say this, I have a uncle who worked for Chevron down in California(not a dealer he actually worked for the corporation) and he once said that they sold used motor oil to shipping companies to burn in their ocean vessels. This was 10+ years ago and they had been doing this for a while. I don't know if they refined it in some way but no one seemed worried about it ruining the motors.
  #32 (permalink)
Old 05-15-2008, 03:44 PM
Phydeaux88's Avatar
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Marine diesels for large ships are a totally different animal.
They are designed to run on bunker fuel which is not much more refined than oil straight out of the well. As a result they will run on almost any flammable liquid.
__________________
1996 F250 4X4 Crew Cab: Diablo Flip Chip, Powershot 2000, Hypermax exhaust turbo back, Tymar AIS, All the gauges, Bilstein Shocks, AirLift Super Duty bags on the rear
  #33 (permalink)
Old 05-15-2008, 04:06 PM
460429_freak's Avatar
460429_freak is starting off with a positive reputation.
Quote:
Originally Posted by fabmandelux View Post
I don't think you'll find many people here that will "flame" you
It's your truck, your $$$$, and your decision. I never have a problem with others using whatever they want to.
The only time I have a problem is when somebody PROMOTES the use of WMO or UNHEATED WVO. Somebody sometime will try it and ruin an expensive engine.
Yes, I promote the use of Biodiesel. I do this from experience (4 years) and the fact that I can present study after study that will show the use of QUALITY MADE Biodiesel will not harm an engine.
thanks...you know everybody at first thought you was crazy for using wvo.. this is why I'm trying it out on a bad motor I've had the injectors out pop tested them and I put this IP on from a $100 parts motor... when I swap motors or this one goes boom then I'll pull it apart and see what has happend ... the next moto in my truck is a rebuitl 6.9 from a south western bell truck... when it runs it sound like a gasser very quiet ... well did the guy that had it did'nt treat it right it needs injectors and GP's
__________________
Can't list my Ford's only allowed 300 letters.... to many to list
FORDS always look better when pulling a CHEVY
  #34 (permalink)
Old 05-19-2008, 01:58 AM
ta5150 is starting off with a positive reputation.
Well I've got 414 miles now on my oil mix. I just filled up tonight with just over 50% wmo, the rest pump diesel. This is slightly higher than the first tank by maybe 10% I guess. So tomorrow we shall see if there is any change. No clogged filters yet, no problems to date.
  #35 (permalink)
Old 05-19-2008, 01:28 PM
so far 1000 plus miles truck runs fine everything else went to crap on it (batterries air pump) found out why I might have been clogging filters bad oil (my 2cnd supplier) clogged 2 of my filter filetrs in 30 gallons last night... will have to do something differnt with his oil... and just run the 1st suppliers oil .. (ran 500 plus miles on that filter....
__________________
  #36 (permalink)
Old 05-20-2008, 03:39 AM
Got about 50 miles on the heavier concentration. This makes somewhere around 460 miles total on wmo mix. Truck warms up faster. Engine is quieter, less knock. Still about the same smoke, maybe a little more. I don't think there is any more or less power, feels the same. This is at somewhere between 50 and 60 percent wmo. I'll burn this tank, next one will be 60-70 percent. Still no issues.
  #37 (permalink)
Old 05-27-2008, 08:52 AM
empiretc's Avatar
empiretc is gaining momentum as a positive member of FTE.empiretc is gaining momentum as a positive member of FTE.
i am curious as to what chemicals/additives (if any) you are using.
__________________
David
1999.5 (05~07 looks) CrewCab ShortBox 2WD - 185k
6637; A/C Valve; Sonnax; SS HPX; Muffler Delete; Pyro/Boost/Trans/Water/Volt/Fuel & Oil pressure; DP 80HP Econo; Hutch; Harpoon; Stancor GPR w/ LED; 16" Pusher Fan; Tekonsha Prodigy; Kleinn 500 Air Horns
  #38 (permalink)
Old 05-27-2008, 11:24 AM
well I've bumped mine up to a 80-20 so far so good finaly sealed my motor up(block sealer) this has helped alot... was smoking whit and using 2 gallon water for 55 miles...
so the test willl go one until the big boom
__________________
  #39 (permalink)
Old 05-27-2008, 07:04 PM
empiretc- I make my current mix in six gallon batches. 5 gallons wmo, 1 gallon pump diesel, and a dose (1/2 ounce per gallon) of opti-lube xpd formula. I looked at several different additives to use, and this stuff is the best I have found as far as chemical content.
  #40 (permalink)
Old 05-28-2008, 01:28 PM
comp is starting off with a positive reputation.
what do the "toilet paper" canister filter down to ???
  #41 (permalink)
Old 05-28-2008, 02:25 PM
Quote:
Toilet paper, reminds me of a old filter my dad had laying around that used toilet paper rolls as filter elements. I think he had it on a Volvo.
  #42 (permalink)
Old 05-28-2008, 02:28 PM
Quote:
thats it,,,way back people (re-fined) used oil and i think it was toilet paper filters that was used as part of it
  #43 (permalink)
Old 05-28-2008, 03:45 PM
tjbeggs's Avatar
Fisher of Men
tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.tjbeggs has a very good reputation on FTE.
I use a frantz filter on my truck. it uses toilet paper. They claim sub 1 micron filtering. I haven't see those number really backed up in my used oil analysis but there are many who swear by them.
__________________
Tim
Proud User of "The Cure"
For sale- 95 accelerator pedal, Gray interior and dash part, cab and more PM your request!
Click the Picture for wiring diagrams, tech info and Pictures!
  #44 (permalink)
Old 05-28-2008, 03:48 PM
Quote:
is it a add-on set-up ??
  #45 (permalink)
Old 05-28-2008, 03:51 PM
tjbeggs's Avatar
Fisher of Men
Yes its add on
__________________
Tim
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
