Ported vacuum switches - Ford Truck Enthusiasts Forums
Old 01-11-2002, 04:18 PM
ExplicitHP ExplicitHP is offline
ExplicitHP is starting off with a positive reputation.
I am building 1983 351 windsor engine. I just pulled a ported vacuum switch off the thermostat housing. It has 3 ports - "1", "2", and "D". What does this switch do. I have heard that it is egr related and i don't need a new one since all the emmissions had been removed. Someone else said it has something to do with a spark delay valve and the vacuum advance on the distributer. What is a spark delay valve? Do i need this switch? It's $50 bucks at the ford dealer, so i'm hoping i don't. Where can i find a vacuum routing diagram for this engine?
-Jon
Old 01-11-2002, 09:06 PM
Caddy 53 Caddy 53 is offline
Caddy 53 is starting off with a positive reputation.
It run's in my mind that my '85 351w 4x4 c6 had a vac diagram on core support ,hood, or inner fender.This should answer most of your question. I've seen the thermal vac switch used both way,alsovac adv was tied to port off carb above throttle plate and even then it was orficed to regulate when adv was activated. A ford serv manuel would help. Unfortunately I don't have a way to send the picture. Good Luck Chuck Caddy 53:-)
Old 01-11-2002, 09:27 PM
slikness's Avatar
slikness slikness is offline
slikness is starting off with a positive reputation.
More than likely it is the vacuum switch that controls the EGR. It will keep the EGR valve closed until the engine is warm enough to handle the recirculated gases. I lost mine a few years ago??!! You do need a vacuum source hooked to the vacuum advance on your distributor. It should run from the timed port on your carb (usually passenger side front) to the vacuum advance. If the emissions equipment has been removed, you no longer need a thermal vacuum switch.
Old 01-11-2002, 09:29 PM
slikness's Avatar
Vacuum Diagram Acronyms AsianSpanker 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 11-03-2016 11:27 PM
460 vacuum line question dtkkc Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 09-23-2016 04:49 PM
Ported Vacuum Switch for Vacuum Advance? Ford59galaxie 1973 - 1979 F-100 & Larger F-Series Trucks 21 02-12-2016 05:29 PM
Simplifying the Vacuum System of a 390 crazy96863 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 5 07-24-2015 11:56 PM
Simplifying the Vacuum System of a 390 crazy96863 1973 - 1979 F-100 & Larger F-Series Trucks 9 07-24-2015 10:09 AM
Tags
2001, 351, 351w, 85, f250, ford, full, ported, switch, switches, switchess, thermal, troubleshoot, vacuum, windsor
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
