Can't get my fuel filter off ? - Ford Truck Enthusiasts Forums
Old 04-23-2008, 01:09 PM
ADSf100 ADSf100 is offline
ADSf100 is starting off with a positive reputation.
I'm havinf fits trying to get the output side of my fuel filter diconected.
Look like the stem of the fuel filter is to short and there is not enough room to use the special tool.
There is only about 3/16" max room.
Both stems of the new replacement filter are much longer that this one on the truck now.
Can anyone help me ?
Here are a couple pics
<a href="http://smg.photobucket.com/albums/v222/DaleS/?action=view&current=DSC_9370.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v222/DaleS/DSC_9370.jpg" border="0" alt="Photobucket"></a>
<a href="http://smg.photobucket.com/albums/v222/DaleS/?action=view&current=DSC_9383.jpg" target="_blank"><img src="http://img.photobucket.com/albums/v222/DaleS/DSC_9383.jpg" border="0" alt="Photobucket"></a>
Old 04-23-2008, 01:15 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
You're having problems because some butthole put the wrong one on your truck. You can buy replacement clips for inside the line, so just use a pry bar to get it off and replace the clip. Another option is to cut the tube with a hacksaw and they remove it with the tool, but I'm not real crazy about cutting a metal line with gas in it.
Old 04-23-2008, 01:27 PM
spidermonkey's Avatar
spidermonkey spidermonkey is offline
spidermonkey is starting off with a positive reputation.
good info...I noticed that I am in the same boat. was up under my truck and happend to look at the fuel filter and said...hey there's not room for the tool the next time the filter has to come out.
Can you elaborate on these replacement clips? where? how to replace etc.
Thanks,
Old 04-23-2008, 02:20 PM
You can get them on the Help display at the parts store. Once you see them it should be obvious how to replace them. It will certainly be more obvious than me trying to explain it online.
Old 04-23-2008, 03:03 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is gaining momentum as a positive member of FTE.lv2race is gaining momentum as a positive member of FTE.
Don't forget to release the pressure so you don't get an eyeful of gas!
Old 04-23-2008, 03:13 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE.Virto has a good reputation on FTE.Virto has a good reputation on FTE.
Quote:
I don't think I could have put it better myself.
I'd like permission to use this as my signature quote.
Old 04-23-2008, 03:37 PM
Quote:
Granted as long as the source is properly credited.
Old 04-23-2008, 04:06 PM
quicklook2's Avatar
quicklook2 quicklook2 is offline
quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.quicklook2 has a very good reputation on FTE.
bend it back and forth to break the wrong filter out of the way.
use tool to remove what is left.
put on new filter.
drink a beer or 2 for job well done.
Old 04-23-2008, 04:44 PM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
You CAN NOT just buy new clips in the Help section for that line. That one takes the tool, as discussed, the little clips that are shown on the filter on the left in the pic, are not for that type of line. That line has a little round spring that holds it on, that is what the tool expands so you can get the line off.
Old 04-23-2008, 08:33 PM
mr. Charles's Avatar
mr. Charles mr. Charles is offline
mr. Charles is starting off with a positive reputation.
Talking
.........just to give my experience for this SUCH problem: i ran into this a couple of times, already; my way of accomplishing removal = you need to use a large pair of diagonal cutter's (wire_cutter's) and get a good Crimp of, Almost cutting off the round canister-filter, then you can bend back & forth to break off: if worried about's heat and gas, just dilute with some oil or H2o, [ better yet, use some Whip Creme or even Shaving creme, ] . Then, once you have line broken off, use needlenose pliers to make the crimp'd line back to a "round" look of and commence to use the fuel-line_tool to get the fuel line off the small left over piece; then just replace with the RIGHT / Correct Filter ! ! ! . . . . . again, just my 2 cent's of help out for ya...........good luck.......
mr. Charles
Old 04-23-2008, 09:36 PM
Quote:
Yes, you can. We keep a package of them at work for situations just like this. The little stamped steel ring with fingers on it is available at the parts store. I don't seem to remember anyone saying the plastic clips did fit his application.
Does anyone else find it ironic that the long style filter almost always includes the plastic clips for the short style, but the short style often doesn't have them?
Old 04-23-2008, 10:06 PM
Which style do you want?
Dormna PN 800-008:
Dorman PN 800-025:
Old 04-23-2008, 10:09 PM
bradshaw6243's Avatar
bradshaw6243 bradshaw6243 is offline
Old, but not too old
bradshaw6243 is a splendid one to beholdbradshaw6243 is a splendid one to beholdbradshaw6243 is a splendid one to beholdbradshaw6243 is a splendid one to beholdbradshaw6243 is a splendid one to beholdbradshaw6243 is a splendid one to behold
I can tell you what, it would be nice if our trucks used the plastic clips. Some older Fords I had used the plastic clips. They work and are a breeze to change.
Old 04-23-2008, 10:16 PM
icrman icrman is offline
icrman is starting off with a positive reputation.
The pressure is gone, since the one end is dissconnected, and it will not hurt to cut it off. You might try a fine tooth hacksaw, just make sure no metal chips go in the line.
Old 04-24-2008, 06:54 AM
MisterDave2 MisterDave2 is offline
MisterDave2 is gaining momentum as a positive member of FTE.MisterDave2 is gaining momentum as a positive member of FTE.
Mine was such a PITA that I ended up reassembling the pieces and taking it to my mechanic and he spent almost an hour on it. I personally HATE these filters and their design, but too late I have two trucks with them.
460 Flex plate question with pictures. Highboy74 1973 - 1979 F-100 & Larger F-Series Trucks 1 04-16-2012 09:04 PM
First paint job JDBB neversosure Paint & Bodywork 4 05-19-2010 11:10 PM
My bed fell off..... Fordbronco69 1999 - 2003 7.3L Power Stroke Diesel 62 01-18-2010 09:00 PM
Looking for replacement Heater/ A/C flexible ducting for Factory A/C swap - Pic's Crew_Cab_78 1973 - 1979 F-100 & Larger F-Series Trucks 12 11-28-2009 09:40 AM
Johnny's Wrecker captradiator 1948 - 1956 F1, F100 & Larger F-Series Trucks 16 02-28-2006 04:38 PM
Tags
06, 1987, 2001, 2006, canister, diconect, escape, f150, filter, ford, fuel, hacksaw, lines, remove, round
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
