Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 04-23-2008, 02:09 PM
ADSf100 ADSf100 is offline
ADSf100 is starting off with a positive reputation.
Can't get my fuel filter off ?
I'm havinf fits trying to get the output side of my fuel filter diconected.
Look like the stem of the fuel filter is to short and there is not enough room to use the special tool.
There is only about 3/16" max room.
Both stems of the new replacement filter are much longer that this one on the truck now.
Can anyone help me ?
Here are a couple pics
Photobucket
Photobucket
  #2 (permalink)
Old 04-23-2008, 02:15 PM
Silver Streak Silver Streak is offline
Silver Streak is gaining momentum as a positive member of FTE.
You're having problems because some butthole put the wrong one on your truck. You can buy replacement clips for inside the line, so just use a pry bar to get it off and replace the clip. Another option is to cut the tube with a hacksaw and they remove it with the tool, but I'm not real crazy about cutting a metal line with gas in it.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
  #3 (permalink)
Old 04-23-2008, 02:27 PM
spidermonkey's Avatar
spidermonkey spidermonkey is offline
spidermonkey is starting off with a positive reputation.
good info...I noticed that I am in the same boat. was up under my truck and happend to look at the fuel filter and said...hey there's not room for the tool the next time the filter has to come out.
Can you elaborate on these replacement clips? where? how to replace etc.
Thanks,
__________________
Delray
94 F150 Supercab Flareside, 5.8, 3.73's, gt40 heads, BBK headers, Basani Y-pipe, Vortech S-Trim, Cervini Ram Air, Lowered 2/4
  #4 (permalink)
Old 04-23-2008, 03:20 PM
You can get them on the Help display at the parts store. Once you see them it should be obvious how to replace them. It will certainly be more obvious than me trying to explain it online.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #5 (permalink)
Old 04-23-2008, 04:03 PM
lv2race's Avatar
lv2race lv2race is offline
lv2race is starting off with a positive reputation.
Don't forget to release the pressure so you don't get an eyeful of gas!
__________________
J Lowe
'90 F-150, 4.9 SOLD
'00 Expo, Triton 5.4
'06 F-150 STX, 4.6
  #6 (permalink)
Old 04-23-2008, 04:13 PM
Virto's Avatar
Virto Virto is offline
Virto has a good reputation on FTE. Virto has a good reputation on FTE.
Quote:
I don't think I could have put it better myself.
I'd like permission to use this as my signature quote.
__________________
1990 Ford F-150 XLT Lariat Supercab - 5.0/E4OD - Dead and gone.
1993 Ford F-150 XLT Supercab - 5.0/AOD - 3.55
  #7 (permalink)
Old 04-23-2008, 04:37 PM
Quote:
Granted as long as the source is properly credited.
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #8 (permalink)
Old 04-23-2008, 05:06 PM
quicklook2's Avatar
quicklook2 quicklook2 is online now
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
bend it back and forth to break the wrong filter out of the way.
use tool to remove what is left.
put on new filter.
drink a beer or 2 for job well done.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #9 (permalink)
Old 04-23-2008, 05:44 PM
jas88's Avatar
jas88 jas88 is offline
jas88 is gaining momentum as a positive member of FTE.
You CAN NOT just buy new clips in the Help section for that line. That one takes the tool, as discussed, the little clips that are shown on the filter on the left in the pic, are not for that type of line. That line has a little round spring that holds it on, that is what the tool expands so you can get the line off.
__________________
1991 F150 SuperCab 4.9L/ZF5
1991 Bronco SAE 5.0L/E4OD
2005 Escape 2.3L/CD4E
  #10 (permalink)
Old 04-23-2008, 09:33 PM
mr. Charles's Avatar
mr. Charles mr. Charles is offline
mr. Charles is starting off with a positive reputation.
Talking
.........just to give my experience for this SUCH problem: i ran into this a couple of times, already; my way of accomplishing removal = you need to use a large pair of diagonal cutter's (wire_cutter's) and get a good Crimp of, Almost cutting off the round canister-filter, then you can bend back & forth to break off: if worried about's heat and gas, just dilute with some oil or H2o, [ better yet, use some Whip Creme or even Shaving creme, ] . Then, once you have line broken off, use needlenose pliers to make the crimp'd line back to a "round" look of and commence to use the fuel-line_tool to get the fuel line off the small left over piece; then just replace with the RIGHT / Correct Filter ! ! ! . . . . . again, just my 2 cent's of help out for ya...........good luck.......
mr. Charles
__________________
1996 F-150 XLT 4x4 Reg Cab_ShortBox / 5.8L / E4OD / Automatic / 3.55 LS / 4" SkyJacker Class II Suspension Lift kit
15"x10" Mickey Thompson's Classic II wheel's with = 33"x12.50" Mickey Thompson's BAJA Claw_Radials
2C_Gallery~album's >>>click-here<<<
...comments/suggestions=welcome'd...
  #11 (permalink)
Old 04-23-2008, 10:36 PM
Quote:
Yes, you can. We keep a package of them at work for situations just like this. The little stamped steel ring with fingers on it is available at the parts store. I don't seem to remember anyone saying the plastic clips did fit his application.
Does anyone else find it ironic that the long style filter almost always includes the plastic clips for the short style, but the short style often doesn't have them?
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #12 (permalink)
Old 04-23-2008, 11:06 PM
Which style do you want?
Dormna PN 800-008:
Dorman PN 800-025:
__________________
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
  #13 (permalink)
Old 04-23-2008, 11:09 PM
bradshaw6243's Avatar
bradshaw6243 bradshaw6243 is offline
Up, Up and Away
bradshaw6243 has a great reputation on FTE. bradshaw6243 has a great reputation on FTE. bradshaw6243 has a great reputation on FTE. bradshaw6243 has a great reputation on FTE. bradshaw6243 has a great reputation on FTE. bradshaw6243 has a great reputation on FTE.
I can tell you what, it would be nice if our trucks used the plastic clips. Some older Fords I had used the plastic clips. They work and are a breeze to change.
__________________
Jim
1995 F-150 351 Auto. Ext.Cab SWB
http://i208.photobucket.com/albums/b...ppi-flag-1.jpg
"Watch out where the Huskies go, and don't you eat that yellow snow" Frank Zappa
  #14 (permalink)
Old 04-23-2008, 11:16 PM
icrman icrman is offline
icrman is starting off with a positive reputation.
The pressure is gone, since the one end is dissconnected, and it will not hurt to cut it off. You might try a fine tooth hacksaw, just make sure no metal chips go in the line.
__________________
1996 F-250, XLT 460 E4OD, Long box, Supercab 4X4, 4.10 Axle Ratio, Camper and tow package.
Self install of: Clifford alarm, B&W Flipover gooseneck hitch, Ride Rite airbags, and compressor system, Prodigy Brake controller.
  #15 (permalink)
Old 04-24-2008, 07:54 AM
MisterDave2 MisterDave2 is offline
MisterDave2 is starting off with a positive reputation.
Mine was such a PITA that I ended up reassembling the pieces and taking it to my mechanic and he spent almost an hour on it. I personally HATE these filters and their design, but too late I have two trucks with them.
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
