97 F150 no start just a single click - Ford Truck Enthusiasts Forums
Old 04-23-2008, 02:07 PM
mmullin mmullin is offline
mmullin is starting off with a positive reputation.
Hello to all,
I have a question about my 1997 F 150 that will not start. When you turn the key all you hear is a single click. Then if you wait a while, try a few times more, sometimes all of a sudden it starts.
Any sugestions? I replaced the selenoid on the starter about 3 months ago, and I am now woundering if it may be the relay, mounted on the passengers fender, or if I should just replace the starter and selenoid together.
Thanks in advance.
Old 04-23-2008, 02:26 PM
150mudder's Avatar
150mudder 150mudder is offline
150mudder is starting off with a positive reputation.
my truck was doing the exact same thing and the cause was a bad starter motor. once i replaced it, the truck starts up with no problems at all. also make sure your battery is good and fully charged.
Old 04-23-2008, 03:57 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
My guess is the fender mounted solenoid, cheap guess and easy to get to. Most times one click per turn of the key is solenoid..multiple clicks per turn of the key is insufficent (sp) voltage to the starter or a bad starter.
Old 04-23-2008, 04:21 PM
150mudder's Avatar
i didnt think these trucks had the remote(fender mounted) solenoid some one correct me if im wrong. i believe the solenoid is located on the starter assy.
Old 04-23-2008, 04:24 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
There is a starter relay on the fender well and a starter solenoid on the starter.
Old 04-23-2008, 05:56 PM
150mudder's Avatar
ah, thanks. i didnt know that.
Old 04-23-2008, 07:34 PM
archer1 archer1 is offline
archer1 is starting off with a positive reputation.
Your problem is the main red thick wire the end piece that connects to the starter is shot REPLACE it and watch the results.
Old 04-23-2008, 07:38 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
I am also betting you have a bad connection, either the ends are dirty or a cable is bad.
Old 04-23-2008, 10:40 PM
mrsteveo19761982 mrsteveo19761982 is offline
mrsteveo19761982 is starting off with a positive reputation.
Clean all battery terminal connections and starter connections. It sounds simple but less resistance equals more amps.
Old 04-24-2008, 12:29 AM
rambaseball45 rambaseball45 is offline
rambaseball45 is starting off with a positive reputation.
yeah id replace starter. happened to me
Old 04-24-2008, 12:20 PM
Galaxy, archer, and mrsteveo all have good advice that you would do well to check out on your truck before replacing the starter. Good luck!
No start, No crank. BlueOval351 1987 - 1996 F150 & Larger F-Series Trucks 2 04-18-2015 08:06 PM
issues with starter and selenoid westbrooka1 1987 - 1996 F150 & Larger F-Series Trucks 22 07-24-2014 08:44 AM
Stater overheating? (kinda long winded) jitterymonkey Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 5 11-12-2013 09:07 PM
1994 F150 ignition problem joe0854 1987 - 1996 F150 & Larger F-Series Trucks 0 04-28-2012 10:13 PM
Bad neutral safety switch? llee 1987 - 1996 F150 & Larger F-Series Trucks 3 04-08-2009 06:15 PM
Tags
97, clicks, f150, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
