Where to but green antifreeze with sca allready in it?
Well, I found 4 threads that I started about coolants way back when... check them out, might help you...
https://www.ford-trucks.com/forums/5...ed-system.html
https://www.ford-trucks.com/forums/5...mendation.html
https://www.ford-trucks.com/forums/4...endations.html
https://www.ford-trucks.com/forums/4...th-sucess.html
-Robb
-Robb
Napa sells a green anti-freeze premix with SCA added for trucks, I just don't recall the name but it has a photo of a big rig on it.
Also, use a cleaner that will flush the old SCA from f the walls of the engine as SCA has a tendency to build up and this reduces the cooling effect of the coolant.
Rog
Rog
http://www.penray.com/images/PenrayTechFacts_1.pdf
Read this as it holds a wealth of info re the cooling system.
Rog
Rog
Murrrr!!!!! When I was doing my coolant search every NAPA I called said they only had Prestone ELC or something like that... no SCA stuff. I wish the people there were more educated! Thanks Rog I'll keep an eye out for this next time...
-Robb
Robb, I just found out the other day when someone reported that Napa was having a huge sale on our fuel filters and he bought a case of them.
When I inquired at my local Napa store I found out that some stores are Napa owned and operated while the others are franchise stores.
The Napa store by me (Franchise) has a separate "Big Rig" department area separate from the normal flow of folks that are just buying parts for there autos.
This could be some of the reason (s) that some of us can find different deals at different stores.
Rog
Rog
