Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-23-2008, 12:48 PM
littlemac is starting off with a positive reputation.
fuel leak 94 IDI Turbo
have leaking fuel coming from passenger side engine. Its been leaking for quite sometime, but stops when engine is warmed up and running. I would like to fix this problem myself, as I am long ways to diesel mechanic. It looks like the leak is coming from the return line cap, under the Turbo area!! Looks like a difficult place to work on. Do I need to take the Turbo off, and if so, is there a sequence in doing so? I thought I might change out the glow plugs also. Any suggestions would be greatly appreciated.
  #2 (permalink)
Old 04-24-2008, 02:41 PM
PLC7.3 is gaining momentum as a positive member of FTE.
Not sure about turbo removal.....I would think not. There is very little work area for sure and some have overcome the problem by adapting different tools than normal. For GPs you may have to change to smaller wrenches/socket set.
Hoses/return line/caps are not hard but space again my cause difficulty........
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 04-24-2008, 10:46 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
You can swap the return lines without to much trouble with the turbo installed.
Easy job, can be done in under an hour the second time you do it.
First time, budget a little over 2 hours for the job..
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #4 (permalink)
Old 04-29-2008, 12:54 AM
rupejosh's Avatar
rupejosh is starting off with a positive reputation.
check the fuel line down next to the block on the passenger side there was a fitting on my line that came loose down there
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
