have leaking fuel coming from passenger side engine. Its been leaking for quite sometime, but stops when
engine is warmed up and running. I would like to fix this problem myself, as I am long ways to
diesel mechanic. It looks like the leak is coming from the return line cap, under the Turbo area!! Looks like a difficult place to work on. Do I need to take the Turbo off, and if so, is there a sequence in doing so? I thought I might change out the
glow plugs also. Any suggestions would be greatly appreciated.
