moto metal dually rims - Ford Truck Enthusiasts Forums
Old 04-23-2008, 12:36 AM
jhnlennon's Avatar
jhnlennon jhnlennon is offline
jhnlennon is starting off with a positive reputation.
does anyone know if the moto metal 953 series dually rims will fit on a 1985 f350? i cant find out any info on the web about it. they were off a chevy dually. i know they have a conical lug seat on them( stock rims are hub centric on ford right?) but could i just get conical lug nuts? any info would be appreciated.
Old 04-23-2008, 12:43 AM
PLC7.3 PLC7.3 is offline
PLC7.3 is gaining momentum as a positive member of FTE.
What is the rim size....... 16x6 I see ads showing the newer sized bolt pattern 8x170 only. I also saw info stating Chebby and Dodge work together but appears Ford is a loner. Just google your headline.
Ford F-250/350 single rear wheel :
1997-Back = 8-6.5" bolt circle
1999-up = 8-170MM bolt circle.
Ford F-350 Duallys as follows:
1999-2004 = 8-170MM bolt circle
2005-up = 8-200MM bolt circle
Old 04-23-2008, 01:03 AM
jhnlennon's Avatar
they are 16x6 and they are definately 8x6.5 bolt pattern. i think the hub cutout is big enough, but they are conical style lug seat. my ford has the lug nuts with the flat washers on them which means the hub centers the rim and not the lug nuts right? thats my question will they work with that style lug seat. i know in the rear i have to run the stock steel rim on the inside(i think you have to do that with all the aftermarket alluminum dually rims) is this gonna cuase probs with the lug nut styles being different on the two rims?
Old 04-23-2008, 05:38 PM
Dave Sponaugle's Avatar
Dave Sponaugle Dave Sponaugle is offline
Dave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to beholdDave Sponaugle is a splendid one to behold
Measure the center hole carefully.
80's model Dodge and Ford wheels work on each other.
But many of the Chevy or GMC wheels do not have a big enough center hole to clear the hubs.
Old 04-23-2008, 09:59 PM
jhnlennon's Avatar
what about the lugnut situation?
Old 04-23-2008, 10:10 PM
Even though Ford wheels are hub centric, they still have tapered lug nuts until you go 1999 or newer.
Old 04-24-2008, 01:22 AM
jhnlennon's Avatar
ok, i will measure the center hub diameter. pretty sure that it is big enough by looking at the distance from the lugnut hole to the outside of the hub. there isnt much metal there. i was just worried about the lug nut thing being as the ford rims are hub centric and the moto rims look as if they are lug centric. i can get all 4 for 300 bucks and they are in really good shape.
Help LUG NUT & Washer 15x10 MT forged Alcoas WPanicCrew 1987 - 1996 F150 & Larger F-Series Trucks 9 03-31-2016 12:02 AM
Looking for detailed lug nut info regarding 02 F350 & American Racing wheels gooseman80 1999 to 2016 Super Duty 7 03-06-2016 01:22 AM
Chrome Lug Nuts? 04fivefour Excursion - King of SUVs 0 07-21-2012 01:08 AM
Conical Lug Nuts for Aftermarket Lug Centric Wheels ComputerCowboy Excursion - King of SUVs 11 04-09-2012 08:13 PM
Wheel / Tire size, offset, etc question TXHillCountry 1999 to 2016 Super Duty 10 03-04-2007 11:23 PM
Tags
1985, 8x170, bolt, diameter, dually, f150, f250, f350, fit, hub, pattern, rim, trucks, wheels, www24
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
