Go Back   Ford Truck Enthusiasts Forums > General > Ford vs The Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
  #1 (permalink)
Old 04-22-2008, 09:29 PM
gweeds's Avatar
gweeds gweeds is offline
1994 Ford F-250
My Garage
gweeds is gaining momentum as a positive member of FTE.
Question Might try a pull: Old Ford vs. new GM
So a buddy and I might try to pull against each other, and I was wondering what you guys think. I've never really been into competition at all, and know nothing really about how these engines/drivelines stand up against each other.
Mine: '94 f250 4x4 e4od 7.5L
His: '07 gmc 1500 4x2, 4-spd (?), 5.3L.
Am I just going to get embarrassed?
__________________
-94 f250 XLT 4x4, 7.5L, E4OD
-95 Nissan Hardbody, 2.4L, 5spd <-- The real work horse!
"Greater love has no one than this, that he lay down his life for his friends" - John 15:13
  #2 (permalink)
Old 04-22-2008, 09:45 PM
SUPERDUTY_untouchabl's Avatar
SUPERDUTY_untouchabl SUPERDUTY_untouchabl is offline
Garage is empty, add now
SUPERDUTY_untouchabl is gaining momentum as a positive member of FTE.
Just stand on the brake till he starts to spin then pull him away. Your 460 should have no problem doing that. Throwing some logs our something in your bed wouldn't hurt either. You could use your 4wd for some extra insurance, just dont say anything about it.
__________________
-Josh
04 F150 4.6l Gryphon Powered 2wd reg cab XL 3:55 LS SISO Flowmaster S40 NCD Customs 2.5" Leveling Kit Burner High Power Fog Lights 285/70/17 BFG A/T KO's
  #3 (permalink)
Old 04-22-2008, 10:44 PM
gweeds's Avatar
1994 Ford F-250
My Garage
So... What you are saying is that the GMC can't pull 5000# of dead weight?
__________________
  #4 (permalink)
Old 04-23-2008, 07:31 AM
thorseshoeing's Avatar
thorseshoeing thorseshoeing is offline
thorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant futurethorseshoeing has a brilliant future
You probably have the weight advantage, so you should win...
Tim
  #5 (permalink)
Old 04-23-2008, 07:59 AM
BigF350 BigF350 is offline
2000 Ford F-350
My Garage
BigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputationBigF350 has a superb reputation
adrian.erks.harris adrianerksharris
and the 4x4...
2nd gear low range, Brake, stall it up, till he looses traction, release brake, and wham.
Oh, and did I mention "pull offs" can be dangerous. Keep your head low for a flying hitch through your rear window...
__________________
Adrian | 2005 4x4 Diesel Ranger CrewCab in Aus | 2000 4x4 SC/LB F350 7.3 ZF-6 in the US
  #6 (permalink)
Old 04-23-2008, 12:22 PM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
I see your truck is 4x4 if its a little higher hook short and when to pull you will gain load on your rear tire and he will lose load on his thus giving you a good advantage. I few years back i got cocky and a older guy with a lifted gasser put the whoop down on my 7.3 PSD and explained this simple advantage to me.
__________________
Got beer ? 611 HP 1205 TQ
08 F350 CC FX4, 6.4 PSD,PMF 4.5" LIFT WITH TRACTION BARS,3.73 REAR, NAV ,DASH DAQ, VOLANT INTAKE,SPEARCO INTERCOOLER,STAGE III WATER/METH INJ,67 GAL TITAN TANK,COMPLETE EGR DELETE,ARP HEAD STUDS,71MM LP BILLET TURBO,FS-2500 BYPASS FILTER, AIR DOG II FUEL PUMP,CUSTOM CCV MOD,MAG-HYTEC TRANS PAN AND DIFF COVER, CUSTOM HD TRANS COOLER, SEIC MOD,AMP STEPS
  #7 (permalink)
Old 04-23-2008, 12:25 PM
less less is offline
less is gaining momentum as a positive member of FTE.
It will be down to which truck gets the most traction. Your 460, even though old has2 1/2 liters of displacement over the chevy 5.3...but I think traction, not torque, maybe the deciding factor.
  #8 (permalink)
Old 04-23-2008, 06:54 PM
Not saying that. Just saying your 460 could easily do that. Like mentioned earlier traction is the key.
__________________
-Josh
  #9 (permalink)
Old 04-25-2008, 01:15 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
If I could get the traction, my fourwheeler would outpull your F250
Put yours in 4-Lo, 1st gear and ease on the throttle once the signal has been given. Your automatic is already a HUGE advantage over his manual. Plus, your 4WD pretty much guarantees a win.
Don't forget to lock your hubs!
And if he gets Butt-hurt about using your 4WD...they tell him to forfit.
__________________
-2007 Dodge Ram 2500 4x4
-1988 F350 4x4 7.3L IDI
-1978 F150 4x4 - 466ci/4-spd/1-tons
  #10 (permalink)
Old 04-25-2008, 07:53 PM
gweeds's Avatar
1994 Ford F-250
My Garage
Ha ha thanks everyone. Going to try it sometime in the next week or so, depending on the weather. Ill post a video/results when it happens
__________________
  #11 (permalink)
Old 04-26-2008, 08:52 PM
RDJ184's Avatar
RDJ184 RDJ184 is offline
RDJ184 is a splendid one to beholdRDJ184 is a splendid one to beholdRDJ184 is a splendid one to beholdRDJ184 is a splendid one to beholdRDJ184 is a splendid one to beholdRDJ184 is a splendid one to beholdRDJ184 is a splendid one to behold
dont punch it ..let him hang him self...there is a little skill involved...film it
__________________
JOIN NEW MEXICO CHAPTER HERE!
  #12 (permalink)
Old 05-02-2008, 09:14 AM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
i believe the 460 has more torque than the tundra so ur good in that department.and all i hear about chevies is how u have to rev the crap out of them to get any power
  #13 (permalink)
Old 05-05-2008, 06:01 PM
F250Wildman F250Wildman is offline
F250Wildman is starting off with a positive reputation.
The F-250 will kill the 1500 Gotta Mechanic Coming.
  #14 (permalink)
Old 05-06-2008, 07:27 AM
toddol1971 toddol1971 is offline
toddol1971 is starting off with a positive reputation.
I think these kind of pulls are STUPID. They prove nothing. Go grab a travel trailer or flatbed & put 5 or 6k in it & time a run up a hill somewhere. Use a third person to do the timing & signaling. He will lose. I had a 5.3 & they suck @ towing. Now if he was to drag race you then you will lose. See your both even, no need to do anything now lol.
__________________
87 f150 4x4 302 4spd no od. 3.55 gears. 33 12.50/15's on rock crusher's. Sold to me brother in law.
THINK BEFORE TALKING
  #15 (permalink)
Old 05-07-2008, 12:17 AM
gweeds's Avatar
1994 Ford F-250
My Garage
Quote:
Well, thats true... If you compare, lets say the 460 to the 454, you have to rev the 454 about twice as high to get the same power. They are just designed differently. For towing though, its better to have the power in the lower RPM range.
Quote:
And hey, I'm young and reckless... We do these things...
__________________
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
