04-22-2008, 08:55 PM
need help with the vacum pump
i have a 05 F250 SD 6.0 i have owned for 2months, today i turned on the A/C and it worked fine (air coming through the dash vents) i turned the truck off for about an hour and got back in and the A/C now will only blow through the defrosters i know it has a separate vacum pump for the heater-a/c controls is there a fuse for this pump? i could not find it in the owners man. or its listed by some other name,if not a fuse is there any way to check to see if its the pump it self is not working thanks
