Camshaft casting numbers? - Ford Truck Enthusiasts Forums
Old 04-22-2008, 07:50 PM
hotrodlincoln69 hotrodlincoln69 is offline
hotrodlincoln69 is starting off with a positive reputation.
I have two engines that I would like to know which camshafts they have. Are there casting numbers on the cams that I can interchange? The first engine is a 302 out of a 84 Mustang and I would like to double check if it has the HO cam. The other is a 351w from a 82 F150 and I am wondering if it has the 2v or 4v cam.
Old 04-22-2008, 09:22 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant futureConanski has a brilliant future
No casting numbers that will decode to anything usefull I don't think. Get a dial indicator and measure lobe lift or valve lift with the cam in the motor, that alone will tell you what cams you have.. assuming they are stock.
Old 04-22-2008, 11:44 PM
Blurry94's Avatar
Blurry94 Blurry94 is offline
Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.Blurry94 has a very good reputation on FTE.
Some of the later roller versions had letters stamped near the distributor drive (ZL and ZE), not sure about the earlier version though.
Old 04-23-2008, 04:12 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
There are no casting numbers on camshafts, and casting numbers cannot be cross referenced to part numbers.
Some cams have markings on them.
D5OZ-6250-A .. Camshaft ~ 1981/84 Mustang 255/302 exc. H.O. / Marked: DG or DH with reverse D
D3OZ-6250-A .. Camshaft ~ 1982/84 Mustang H.O. / Not marked / This same cam was used on 1973/75 351W's installed in passenger cars.
D6OZ-6250-C .. Camshaft ~ 1981/85 F150/350 351W 2V / Not marked.
No 351W 4V's till 1984.
Old 04-23-2008, 06:48 AM
Thanks for the help. I pulled the cam from the 302 and it has a HD (DH depending which way I look at it) so from the info it has the ****ty cam. There is also #27 on it.
The 351 isn't the original engine in the truck. It has a rebuild date on it and was bored .040 over. It also doesn't have the original intake.
Ford Camshafts RustyRatRod Ford Truck Parts for Sale 0 05-06-2016 01:20 AM
Help identifying a camshaft Buckeye Rich Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 06-10-2010 02:14 PM
Cylinder head surfacing kotzy Performance & General Engine Building 11 11-27-2005 11:07 PM
what stock FE did this cam come in? 4WD67F250 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 01-20-2004 06:17 AM
edelbrock camshaft experiences? phaffy12 FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 10 06-08-2001 09:10 AM
Tags
1125, 302, 302351w, 406, cam, camshaft, casting, distributor, ford, gears, marked, numbers, racing, stock, ze
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
