need more power / torque
I have a 1994 F-250 with a 302 EFI with mass air and a E4OD transmission . The truck has to carry a service body also . I know this is alot of weight for a small block . I need to increase my fuel milage and power to carry my tools . The rear is a 4.10 ratio . I have been spoiled in the past with the past work trucks having 460 engines in them. I know that I won't get the same performance out of the small block . But it is what I can afford right now . The milage I am getting right now is around 13 miles per gallon . I have changed the engine out to one out of a wrecked 1996 F-150 with 125,000 miles . The old engine was worn out and used more oil than gas . Is there any modifications I can do to increase milage and power . Part of the stock exaust is still on the truck . Part was replaced due to being collapsed .
Thanks for the help . After posting here I went outside to look my truck over . I found the the exhaust is stopped up at the muffler or the tail pipe leaving the muffler . I ran it long enough to see what areas were hot and what areas were cooler . I believe I will redo the whole exhaust system. Where can you find long tube headers for a ford truck ? All I have foud have been for the modular engines and small block Mustangs.
