Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1973 - 1979 F-100 And Larger F-Series Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
1973 - 1979 F-100 And Larger F-Series Trucks Discuss the Dentsides Ford Truck
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 06:47 PM
dionysius is starting off with a positive reputation.
PS Pump Reservoir Leaking?????
Has anyone run into this on a 1979 F150 (400 cu in;2WD;Auto;noCC) PS Pump ???
There is a leak which lets drops of fluid congregate on the bottom of the reservoir. The drops fall from there on to the fuel hose and then to the ground. It is a slow leak but it occurs even when cold. The fluid level drops by one or two inches per month.
After some troubleshooting and use of duct tape to isolate the source it appears that the leakage is from the seam between the metallic front plate and the reservoir body that the filler neck is a part of. What material is the reservoir made of?? It appears to be a strong hi density black plastic but I am not sure. It could be a cast metal.
Has anybody found cracks or leaks on this unit and if so what is a good fix?? JB Weld??
It is not the swivel output since I have covered off this with a towel and tape but leak still appears. Neither is the leak from the pulley bearing.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-22-2008, 06:54 PM
rbaker6336's Avatar
rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.rbaker6336 has a good reputation on FTE.
if it is round resevoir there is an o-ring where body meets resevoir
__________________
Ray
2000 F-350 2WD,DRW Auto, PSD,
DP Tuner,40 Tow 80E,Wicked Wheel 4" Exhaust ,AIS intake, Guages,6.0 Trans cooler to install
DooDad???=(dfuser ram air)
'98 Grand Cherokee
'86 F-150 SB Lariat 4x4 bought new (needs new home)
PAA #35
  #3 (permalink)
Old 04-22-2008, 07:05 PM
UTfball68's Avatar
UTfball68 has a very good reputation on FTE.UTfball68 has a very good reputation on FTE.UTfball68 has a very good reputation on FTE.
I've used JB Qwik several times on P/S components...works for a while and then when I notice a leak again use a little more. Probably should get it fixed properly though to prevent any other damage.
__________________
'77 250 400 Boggers (show)__'96 350 CC 460 SSR's (work)__'79 Bronco 351M 35's (play)
I bow my head to Jesus, stand for my family, love only one woman, and am always proud of what I have.
Standing by my gun and Bible since 1986.
Ben
  #4 (permalink)
Old 04-22-2008, 07:15 PM
Quote:
Yep....it is a round reservoir. Does one have to disassemble and replace O- ring or have you another suggestion????
  #5 (permalink)
Old 04-22-2008, 07:44 PM
Ken460 is starting off with a positive reputation.
I think I seen a new reservoirs at LMC or auto krafters
  #6 (permalink)
Old 04-23-2008, 12:23 AM
rbaker6336's Avatar
Quote:
it slides off,normally have to work it off with a screw driver,not sure about still getting o-ring,it may come with a filter (there's also a filter inside)
I have sealed them with silicon
__________________
Ray
'98 Grand Cherokee
PAA #35
  #7 (permalink)
Old 04-23-2008, 07:46 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
1978 and later F100/350 P/S pump
There are two different Ford P/S pumps used in the 1970's and both have round reservoirs.
F100/350's & Bronco's used Ford pumps (round reservoir).
Econolines used the Saginaw pump, which does not have a round reservoir.
F100/350 & Bronco: The pumps (and the P/S hoses) changed in 1978.
The newer style pump uses a plastic dipstick, its handle is about 2" in diameter. The reservoir is plastic.
The earlier pumps have a metal dipstick, the shield below the handle is about 3/4" in diameter.
The 1978 and later pump does not have a filter inside it.
I doubt you'll find just the O-Ring, you'll need the P/S pump seal kit.
1978/2008
E1AZ3B584A .. P/S Pump Seal Kit (replaces D8AZ3B584A & D9AZ3B584A-this kit is used thru 2008 on some Ford cars & trucks).
MSRP: $10.40 / ftepartsguy.com price: $7.49
FTE sponsor: ftepartsguy.com = Ed Olson @ Parr Ford, BREMERTON WA.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #8 (permalink)
Old 04-23-2008, 01:29 PM
Quote:
F100/350's & Bronco's used Ford pumps (round reservoir).....
1978/2008
My pump, from this info, is the newer plastic reservoir Ford type. It also appears that there is a very fine hairline crack in the bottom of the reservoir.
I have not been able to locate just the plastic reservoir.
What if I remove reservoir; run it through the dishwasher and clean thoroughly; use JB Weld on the cracks (both sides, inside and outside) and reassemble using a new O-Ring ?????
  #9 (permalink)
Old 04-23-2008, 03:06 PM
Ford Parts Guru
My pump, from this info, is the newer plastic reservoir Ford type. It also appears that there is a very fine hairline crack in the bottom of the reservoir. I have not been able to locate just the plastic reservoir.
The reservoir is still available from Ford, the original 1978 part number has been replaced by a newer part number.
You also have to change the dipstick.
It's very common for Ford to update part numbers.
E5DZ3A697A .. P/S Pump Reservoir (replaces D8AZ3A697A)
MSRP: $35.00 / ftepartsguy.com price: $25.00
YF1Z3A006A .. P/S Dipstick (replaces D8AZ3A006A & E6DZ3A006A) / MSRP: $5.90 / ftepartsguy.com price: $4.25
ftepartsguy.com is Ed Olson @ Parr Ford in Bremerton, WA
__________________
  #10 (permalink)
Old 04-23-2008, 10:01 PM
spuritto is starting off with a positive reputation.
dump it man
I've had hella issues with power steering pumps. My advice is to buy a whole new reman from carquest. You pull that thing apart and for some reason it just doesn't like you anymore. After you get the core money back you might be out like 20 bucks. Which is good for the lack of headache in my book.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
