Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 06:29 PM
newo2u is starting off with a positive reputation.
Where to buy: E150 suspension parts
I have read enough here to know the dead spot in the steering on my '01 E150 conversion is caused by something between the steering box and the tie rods. The pittman arm moves in sync with the output shaft on the box, but the link it is attached to doesn't move right away.
I think this is called the center link or drag link?
Will replacing this tighten the connection between it and the pittman arm?
And where do I find one. No one local has one and when I google it I get a bunch of E-Bay listings for the wrong years.
Thanks to the forum for all the help so far.
  #2 (permalink)
Old 04-22-2008, 06:43 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
NAPA
Advance auto
look for moog or spicer parts
house brand parts only if you plan on getting rid of it
__________________
2003 bull 3.0 24v stock
1996 E-350 351
  #3 (permalink)
Old 04-22-2008, 07:08 PM
I tried Advance, the guy was no help.
I believe there is a NAPA store not too far away; I'll give them a try.
Is it a hard thing to replace or just unbolt/bolt?
  #4 (permalink)
Old 04-23-2008, 01:25 PM
Club Wagon is starting off with a positive reputation.
I presume you're not familiar w/tapered connections in these "suspension parts"? No. They don't "just unbolt". Of course 1st off, they have cotter pins. The tapered pins require special tools ('pickle' forks or press) or mechanic's finesse w/NFH to separate.
While its NOT "a hard thing to replace" once you've popped all the tapered bits apart, it IS out of normal DIY ability to properly realign the steering. You can get it close by careful measurements & precautions-then take it to an alignment shop.
Start by carefully centering the steering wheel & be sure not to move it. Each tie rod end has a threaded adjustment coupling, be sure to make all your measurements before loosening these. I'd strongly recommend replacing all the steering rods/joints at once & be certain the ball joints were good. If over 100K I'd replace them as well, then go for alignment.
  #5 (permalink)
Old 04-23-2008, 03:38 PM
OK. NAPA had the parts. Drag link, inner and outer tie rod. Ball joints look good: were replced at some point with greasable ones. Pretty sure I can get the parts replaced. I called a tire place about the alignment and when I told them what I had they said they couldn't do it. Am I going to have to visit the dealer to get this done right?
  #6 (permalink)
Old 04-24-2008, 02:00 AM
Any tire shop that services fleet/commercial vehicles should be able to realign what you need. The 'Twin I-Beam' design dictates that special equipment actually bend these heavy forged 'beams' for one aspect of alignment-but you shouldn't need that & won't be upsetting it w/these steering joints being replaced. Some tire shops have alignment machines for smaller vehicles that might not accomodate the Econoline's width. I have no idea what the options are in your area, you'll need to inquire locally. Sam's Club did an alignment when I put 4 BFGs on my E150.
  #7 (permalink)
Old 04-24-2008, 02:29 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation. NumberDummy has a spectacular reputation.
F2UZ3304A .. Draglink / Fits 1992 thru 2002 E150
MSRP: $137.38 / ftepartsguy.com: $98.92
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997.
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003.
1965 F100 Styleside Pickup / 390 w/Borg Warner T-85N 3 Speed Overdrive / Original owner.
  #8 (permalink)
Old 04-24-2008, 02:18 PM
Good news. You were right; it was becasue of the size of the van. I found a shop that does alignments on RV's and will be able to accomodate the Eonoline. Thanks for your help
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
