Does the position of the muffler in the system affect performance?
Was just mulling over redoing part of the exhaust system on my truck. As it stands the original y-pipe is still intact but some bozo reduced the rest of the system down to 2.25 inch with an ancient glasspack for a muffler. Maybe he thought it would net some kind of benefit, maybe he was just throwing together parts from his backyard. Either way it's going, I'm planning to keep the Y-pipe but step it up to 3 inch with a Flowmaster chambered muffler and I just suddenly wondered if the position of the muffler in the system affects performance. If I put it directly after the Y-pipe the exhaust pulses would hit it sooner...what effect that would have I really have no idea. Anyone want to chime in?
__________________
"Stella"
1978 F250 Ranger - Camper Special
460 Big Block - 750CFM Holley 4160, 4 in Moroso/K&N Aircleaner
C6 Auto
I would image that location could make a subtle difference. But it would be so minor in comparison to other things. Basically if the exhaust is hotter and moving faster, the muffler would have the same effect as being less restrictive and HP and torque would increase, but the difference would be very minor in even the most ideal situations. I would suspect that too close to the engine would sound like crap, or at least sound weird. The sound projection would be terrible. I don't know, it just seems to me that closer to the tailpipe would be better in terms of sound.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
The muffler is a huge heat sink. Hot Rod magazine did some experimenting with exhausts on a Corvette. They found that the further back the muffler was located, the better the exhaust performed. The exhaust gasses didn't cool as fast and allowed the velocity of the gas to remain higher. Don't know how it would effect your truck.
There is nothing wrong with glasspack mufflers, by the way. They usually will give a slight performance increase over a stock system. jd
__________________
In memory of my beloved Sandy, 9/28/53 - 1/24/03
Maybe it's just because the one I've got is ancient and all the glass has burned away inside but I think it sounds like a cement mixer full of cats. For arguments sake if I did get another one how does length factor into it?
__________________
"Stella"
C6 Auto
If it has louvers in it, you don't want it. Even with the louvers turned around they still create a lot of turbulence and don't flow very well.
If it's got a smooth, perforated core, it probably outflows that Flowmaster you wanna put on there.
Oh and more length=quieter. Just have to think about the fact that you've got more surface area and more packing.
__________________ 1994 F250 XLT-Reg cab, 4x4, 5 speed, 7.3 IDI Turbo, manual hubs, ATS upgrade, 4" exhaust w/Hooker MaxFlow, custom intake, pyrometer & boost gauge, turned up fuel http://www.cardomain.com/ride/3055099 1987 Thunderbird Turbo Coupe-Lots of fun stuff to make it go fast & take corners http://www.cardomain.com/ride/306349
so if you turn a louverd glasspack around backwards does it muffle anything or is it just like straight pipes and what brand of glasspacks dont have louvers?
Ditto on what Jim Dandy said... The best performance will be with the mufflers as far back in the system as possible.... We've played with it on the chassis dyno with a couple different cars and pickups.... No huge gains, but ya might as well get any "free" gains you can.... You have to have mufflers, so put them in the back and let the pipes maintian the velocity and move the exhaust heat away from the engine as efficiently as possible.....
__________________
Anybody can restore a classic, takes a man to cut one up......
Well most people just turn them around so they'll be louder.
But even with the louvers backwards they still flow like crap.
I don't know glasspacks that well, but Dynomax's race bullets aren't louvered. Summit Racing's glasspacks might not be also, I dunno.
So if I am correct, since us diesel burners want our exhaust gases cooler then it would be a good idea to put the muffler as close to the engine as possible?
__________________
Current:
1986 Ford F250 XL Exploder-4x4-6.9 IDI-C6
.. body by Rusty Crunchy
1986 Jeep Cherokee Pioneer Limited-2.8L P.O.S.
Past:
1965 Chevy "Assembled" 1/2 ton
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
1967 Buick Special, 310 Wildcat, 2-speed slushbox
1967 Fairlane GT 500, 428 Cobra, twin turbo, NOX
Exhaust gas flows better when hot. It flows like oil. Hot oil or exhaust gas flows better than cooler exhaust gas or oil. Thats one reason to use header wrap or ceramic coatings. To keep the heat in. I would think on a quet rstrictive muffler than being close to the engine would be best but on a more free flowing how much could that really help. The other consideration is if you can stand to have a hot muffler under the cab. It will heat things up inside a whole lot more than a straight pipe under the cab and summer is comming.
thrush glass packs dont have louvers and they stay full diamiter the whole way through Glasspack Muffler Spec
No problems here ... Summer gets up to a balmy 80 for about a week ...
__________________
Current:
Past:
1964 Chevy 3/4 ton
1964 GMC 1/2 ton
one of the most under thought systems in performance response has been in the class 8 trucks, I always had to tinker with that, the best kept secret was to keep the heat in the pipe,remember it is a flue like your chimney by rapping the exhaust system you cause it to run toward the opening in order to exhaust, this creates a drawing effect as well as its forced effect from the turbo. I spent a great deal of time with the boys at diesel injection of Pittsburgh PA. my little truck ran heavy haul and was in the 6to7 hundred hp so heat control was critical, it is amazing what heat wrap will do, along with muffler to the rear and restriction to a minimum, not loud just free flow, lets face it if the power plant has the hp it will sound like it. JNT
