Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 02:07 PM
roostnu074 is starting off with a positive reputation.
turbo 7.3 tanny bolt up to a 6.9
wondering if a 97 7.3 turbo diesel tranny will bolt up to my 6.9 that im dropping into my 74 f250. should i get an automatic tranny or a standard. truck right now is an auto and iv wanted to convert it into a standard just alot of work. but if the auto wont bolt up then ill have to go to standard. anyways let me know
  #2 (permalink)
Old 04-22-2008, 04:30 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
It will bolt up, but you will need the flexplate as well. An aftermarket transmission controller is probably the best option but that will drive the cost up. Just so you know, the E4OD has a wider OD ratio than a 5 speed, not sure if that matters at all.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
