Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 10:01 AM
ws6gta is starting off with a positive reputation.
2004 trailer wiring problem
I just found this site today while I was looking for an answer to my problem. I've ended up looking for over an hour at everything other than an answer to my problem. What a great site. My names Roger I have an 2004 f150 4.6 4x4.
I bought a brand new trailer and went to plug into the 4 pin trailer connector and none of the lights worked. We tried a 7 pin connector that had a 4 pin adapter and that didn't work either. I used 4 pin trailer tester with the lights on it and I had no power. I used my volt meter in both the 4 pin and 7 pin receptacles and had under 1 volt. I checked all the fuses in the fuse box that had anything to do with towing. Anyone got any ideas or know what might be wrong?
Thanks
Roger
  #2 (permalink)
Old 04-22-2008, 10:16 AM
Twinsdad98 is starting off with a positive reputation.
Roger- make sure the trailer tow relay is installed. Sounds like your truck is missing. Can't recall the location from memory, but look at your owners manual and it'll show you.
__________________
2004 Black Lariat F150 Supercrew 4x4
Roush Suspension Kit, Mark LT bed rails, Truxedo Low Profile tonneau cover, Euro Tail lights, chrome handles, Edge, Volant CAI
Summer Wheels : NS Racing Black/Chrome, 20X8.5, Cooper Tires, 305/50R20s.
Project: 1950 F1
Previous:
89 Probe GT; 86 Bronco II (ex gave it away )
  #3 (permalink)
Old 04-22-2008, 10:34 AM
black04lariat's Avatar
black04lariat is starting off with a positive reputation.
Quote:
x2. My relay was in my glovebox, in the same bag as the trailer brake controller wire harness.
It will go in the fuse box in the pass. floorboard.
  #4 (permalink)
Old 04-22-2008, 12:02 PM
The manual says there's two in the fuse box for towing . Both are installed. I've pulled a trailer a few times last year with no problems. Could one of these two relays be bad? Can I test it with a simple volt meter?
Thanks for the reply's I apreciate any help.
  #5 (permalink)
Old 04-22-2008, 01:40 PM
air1jpg's Avatar
air1jpg is starting off with a positive reputation.
Also check your manual and look for any fuses under the hood..
__________________
________________
Jon
2006 Black F-150 FX4 Off Road SCrew 5.4L
6.5' StepSide Box, 20" Off Road Tires, 3.73LS, Backup Camera
Luxury Package, Cobra CB Radio, Tinted Windows
Electric Trailer Brake Controler, Hard Toneu Cover from Undercover(http://www.undercoverinfo.com)
  #6 (permalink)
Old 04-22-2008, 04:58 PM
soxfan81's Avatar
soxfan81 is starting off with a positive reputation.
Quote:
X2 and the relay should plug into #5 relay plug on the pass. side.
__________________
New England Chapter
Florida Chapter
05 XLT Supercrew
06 E250 (Work Van)
  #7 (permalink)
Old 04-22-2008, 09:57 PM
99Trigger3_0's Avatar
99Trigger3_0 has a great reputation on FTE. 99Trigger3_0 has a great reputation on FTE. 99Trigger3_0 has a great reputation on FTE. 99Trigger3_0 has a great reputation on FTE. 99Trigger3_0 has a great reputation on FTE. 99Trigger3_0 has a great reputation on FTE.
This may sound a bit off but maybe checking the ground lead back on factory trailer wiring harness. It bolts up on the upper side of the tubular support in between the spare tire and the back side of the bumper- it should be a tapped hole. I'll try and locate/acquire a pic for you if necessary
__________________
-Rich
Chapters Moderator / '04-'08 F150 Moderator
South Carolina Chapter Leader!
****Join the South Carolina Chapter here!!!***
..Or your own state chapter Here
  #8 (permalink)
Old 04-23-2008, 06:12 PM
Thanks guys for all the advice. I'm gonna check the ground tomorrow and The relay too. I'll let you guys know what I find.
thanks again
  #9 (permalink)
Old 07-07-2008, 04:21 PM
e065206's Avatar
e065206 is starting off with a positive reputation.
I'm having the same problem that ws6gta had. What was the final resolution? I have towed in the past with no problems with the lights. Suddenly, nothing on the trailer works.
When I connect trailer to someone else's truck it works fine so I know it isn't the trailer wiring. All my fuses are good.
I'm anxious to hear if it was a relay or a ground. If so, which relay?
__________________
-Vinny
  #10 (permalink)
Old 07-07-2008, 07:37 PM
fx4local3284 is starting off with a positive reputation.
Im having a problem with my left turn signal not working when i have a trailer hooked up. all lights work on trailer when hooked up to my buddys truck. anyone have any ideas.
  #11 (permalink)
Old 07-08-2008, 11:47 AM
e065206's Avatar
I found the problem on my trailer. The pigtail on the trailer got crimped and two wires shorted together blowing out all the bulbs on the trailer. I replaced the pigtail and bulbs and I'm good to go.
Fx4local3284 - there are specific fuses for left turn trailer ligts (as well as right turn trailer lights). Check your fuse.
__________________
-Vinny
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
