Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 09:06 AM
dyoung14 is starting off with a positive reputation.
i need more power
hello i am new to this forum and iam need some help i have a 1989 ford f250 with a 7.3 idi and i need more power to tow my 28ft. pontoon boat i know that a few companies makes turbo kits but i dont have enough money do buy a turbo. so could you please help me?
  #2 (permalink)
Old 04-22-2008, 08:56 PM
PLC7.3 is gaining momentum as a positive member of FTE.
What is the rear axle ratio, what trans do you have, how many miles on the engine/trans..... What size tires are you using, how old are the injectors and IP.
Is it really power or speed you want...........
__________________
93 F250 SC 4x4 E4OD 355LS
  #3 (permalink)
Old 04-22-2008, 09:04 PM
David85's Avatar
David85 is gaining momentum as a positive member of FTE.
Keep an eye out for used turbo kits. I lucked out and got one nearly complete for $200 (going rate is usually $500 for a decent used kit). Ebay has them from time to time, but if there is a wide spread classifies network in your neck of the woods keep an eye on that too. I found my kit in a local ad.
Adding a ram air intake will help a little, opening up the exhaust can also help a little.
As PLC said though, what is the rest of the condition of the vehicle?
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #4 (permalink)
Old 04-22-2008, 11:31 PM
Dave Sponaugle's Avatar
Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE. Dave Sponaugle has a great reputation on FTE.
dyoung14,
Welcome to FTE and the IDI diesel forum.
How heavy is the boat?
__________________
86 F250 HD 6.9 IDI ATS turbo "not exactly" stock 4x4 T19 BW1345 3.55LS both ends D60 front, 10.25" Sterling rear, ram air, dual stacks.
"I dig dirt"
FTE Guidelines
FTE Moderator IDI diesel forum
WV Chapter Member
  #5 (permalink)
Old 04-23-2008, 09:14 AM
it has 3.73 gear ratio 5 speed trany 84,567 miles not sure how many miles is on ip or injectors and my tire size is 285/75/16 something like a 33, im not really sure how much the boat ways but i know that it is 28ft long and when i start up the mountain the speed will drop from 50 to 35 40 mph id liked to at least hold 50 or 55 mph on the road so i wouldnt have like three hundred people passing me
  #6 (permalink)
Old 04-23-2008, 05:54 PM
Trying to hold 55 or even 50 means a turbo is what you are looking for.
Without more air in the engine, it just won't happen.
A more open exhaust and a ram air might get you a couple MPH faster, but that is about it.
Most pontoons are wide, so not only are you pulling weight, but you are also catching a lot of air with the boat.
When pulling the hills, do you see any smoke out the exhaust?
What color?
How does it run empty?
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #7 (permalink)
Old 04-24-2008, 09:07 AM
unloaded it will pull the mountain 50 mph in 5 gear when i pull the pontoon boat i dont see a lot of smoke but when i shift down i see a puff of black smoke when it goes back in to gear but right after that it clears up
  #8 (permalink)
Old 04-24-2008, 10:31 PM
Sounds like the fuel is set about right for the amount of air you have going into the engine now.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
  #9 (permalink)
Old 04-25-2008, 09:05 AM
and i also forgot to say that it will puff some black smoke out when i take off from a dead stop in 2nd gear. ive read were people made there own ram air intakes could yall give me any ideas own how to do that
  #10 (permalink)
Old 04-25-2008, 09:28 PM
Several different versions here, this is mine.
__________________
"I dig dirt"
FTE Guidelines
WV Chapter Member
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
