Go Back   Ford Truck Enthusiasts Forums > Misc. > Clutch,Transmission, Differential, Axle and Transfer Case
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-22-2008, 12:51 AM
jav409 is starting off with a positive reputation.
C6 kickdown problem
I recently replaced the manifild and carb in my 66 f100 352 / C6. I purchased a kickdown cable and installed it adjusting the cable to pull back on the lever ( toward the rear of trany ) at WOT it pulls the lever all the way back. I have no kickdown, i dont remember it kicking down before but it didnt have muchlow end grunt with the 2 barrol anyways, now it has a lot more low end power and would like it to kickdown when the 2nd barrols kick in.Am I not adjusting the cable correctly ? it shifts up great and down at stoplights, just doesnt seem to want to kick down when I punch it. Any Ideas ?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 04-22-2008, 01:42 AM
dgrant09 is starting off with a positive reputation.
I found our Kick Down Lever that goes into the transmission was only spot welded at the factory and the weld had broken. This allowed the lever to rotate freely and not engage the transmission. I was able to drop the transmission pan, filter, and the valve box with all of the shifting controls (be careful not to tip or drop this (I heard there were small BB like devices that could be lost), and then I was able to replace the lever. It rides inside the shifter lever. I should have put a new seal in for this shaft area, now it is seeping a little fluid. I took the old one to a transmission shop and they matched it with a used one for $5.00.
__________________
72' F250, Camper Special
2WD, 390
  #3 (permalink)
Old 04-22-2008, 10:55 AM
I feel resistance on the lever and it looks to be moving the whole piece .Is the lever suspost to rotate Clockwise or counter clockwise ? I have it set up to pull clockwise.
  #4 (permalink)
Old 04-22-2008, 12:36 PM
BaronVonAutomatc is starting off with a positive reputation.
Counter clockwise. I use a Lokar cable, it bolted to the top rear of the tranny and pulls the arm up - i.e. counter clockwise.
__________________
1986 Bronco w/300 I6 & ZF 5-Speed
1982 F250 4x4 w/302 & C6
  #5 (permalink)
Old 04-22-2008, 12:53 PM
Sounds like that my problem then, Ill flip the lokar arm over from the topto the bottom and readjust and report back. Thanks!
  #6 (permalink)
Old 04-22-2008, 08:06 PM
I'll have to look into the Lokar cable. It would be nice to have the kick down again!
__________________
2WD, 390
  #7 (permalink)
Old 04-26-2008, 08:59 PM
That was it . now it's kicking down just fine.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
