Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-21-2008, 08:52 PM
royzell is starting off with a positive reputation.
Question 7.3 not starting, ??
Hi All,
my '88 7.3 won't start without a jump-start. It was fine until recently
I tested the glowplugs today with a test light, and all seem fine. The batteries could be one area. They are matched 950CA, 730 CCA. I would have liked higher amps but these were out of a parts truck and 1 1/2 years old. They are the type with the 'green eye' for when they are charged and appear OK. I put them in about 4-5 months ago. The glowplug cycling system and wait to start light all appear OK, but no testing done.
When I try to start for the 1st time it pushes smoke out the exhaust, but doesn't turn over quick enough to start. The batteries drain down very quickly. The starter is about 4 years old.
When I boost it with my spare 950 CCA battery, it starts.
The alt. gauge is way over in the drained/ charging position.
Could my starter be going, need new (Stronger) batteries, or ??
__________________
88 F-250 ext cab, 7.3, C-6, 3:55, 4WD, aftermarket modified powerstroke turbo with intercooler
84 Mercedes 300SD turbo-diesel(parts car also)
93 Honda Accord
77 Chev Class C Motorhome
and other rusty or rugged parts vehicles...
  #2 (permalink)
Old 04-21-2008, 10:11 PM
matts156's Avatar
matts156 is starting off with a positive reputation.
Check your terminals and make sure they're good and clean. I had a problem with mine and it turned out that it was always starting off of one battery, and the other's terminal was corroded to the point where the sudden current demand killed the connection.
__________________
"Main Battle Tank"
1993 F250 Supercab 7.3L IDI N-A E4OD, 3.55 Non-LS
33x12.5x16.5 tires 263K miles
Mods
B&M Electronic Shift Improver
4"-inch exhaust with ATS muffler
Remote Starter
Power windows/door locks from an '89.
"The War Machine"
1984 Mustang GT 6-speed, 300+HP... for now.
Currently in mothballs
  #3 (permalink)
Old 04-22-2008, 05:46 AM
PLC7.3 is gaining momentum as a positive member of FTE.
You have already identified the problem........ batteries. You will kill a good starter if you continue. Go to Wallymart and get 2-1000CCA batteries cheap but good. As above check the wires......
__________________
93 F250 SC 4x4 E4OD 355LS
  #4 (permalink)
Old 04-22-2008, 10:54 AM
Thanks guys, I had a feeling it was the batteries. Are Wally-Mart batteries good ? I've never used them.
I can get a discount of 10-15% on Interstates at a shop I deal with, but will still probably be twice as much. Will Interstate last twice as long as WalMart batteries ?
My main battery cable was replaced a few months ago with a new one from the parts truck. I'll re-check connections as well.
Thanks
__________________
93 Honda Accord
  #5 (permalink)
Old 04-27-2008, 03:01 PM
Hi all,
'got er fixed. I bought 2 new Crown brand 1100CA (They tested at about 1050 CCA) batteries from a local auto-electric shop. $105 each. The truck started better but still seemed to be turning over slow, and took 2-3 tries to start. It seemed to be draining the new batteries already.
I had a spare mitsubishi starter, about 1 month old from a wrecked truck that I bought on e-bay 'just in case'. It still had all the stickers on it and was shiny. I paid $16 plus $38 shipping. I put that on this morning, and could immediately tell the difference. It turned over probably twice as fast and fired cold on the first try. It hasn't done that in ages. I'm happy.
Thanks Guys
__________________
93 Honda Accord
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
