hot rodding a 534? - Page 2 - Ford Truck Enthusiasts Forums
hot rodding a 534?
Old 01-15-2010, 10:01 PM
Louisville Joe Louisville Joe is offline
Louisville Joe is gaining momentum as a positive member of FTE.Louisville Joe is gaining momentum as a positive member of FTE.
You just have so much working against you on the 534. Excessive weight (about 1100 lbs.), very heavy reciprocating assemble (forget anything north of 4000 r.p.m.'s), and a really screwed cylinder head with small ports and valves, not to mention the combustion chamber being formed by the block deck being machined on an angle and a 'plank' head. The intake manifold is really stange on a lot of them too, partially cast in the heads. Even if you could do something with a 534, what are you going to put it in, an F-800? Really tall for any pickup truck. I know a guy that built a 478 GMC V-6 and put it in a '69 GMC pickup. It actually worked, the smaller V-6's were used in pickups, so the installation wasn't a problem, and the 478 had some pretty good heads and manifolds. He used a huge Holley 2 bbl. carb. and had a cam custom ground. A really neat truck when he was finished, but a big block would have done better at half the price!
92-97 interior gray BiGGreen350 Ford Truck Parts for Sale 37 10-27-2014 03:25 PM
Looking for 534 carb, linkage parts dmanlyr 401, 477, & 534 SD Engines 4 12-17-2013 04:09 PM
Found somecool pictures malcolmjohn 401, 477, & 534 SD Engines 0 02-01-2011 12:50 PM
534 engine details emeril 401, 477, & 534 SD Engines 9 11-02-2009 06:56 PM
477/534 swap mrautocar 401, 477, & 534 SD Engines 3 04-14-2007 11:49 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
534, boost, carburetor, engine, engines, fire, ford, gas, hot, motor, performance, seamaster, thermal, truck, trucks, turbo, turbocharged
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
