Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-21-2008, 08:21 PM
HKusp's Avatar
Hates Liberal Pansies
HKusp has a great reputation on FTE. HKusp has a great reputation on FTE. HKusp has a great reputation on FTE. HKusp has a great reputation on FTE. HKusp has a great reputation on FTE.
7.3 guy has 6.0 question regarding p0404 code
My buddy has an '07 F350 xlt 4x4 with 45K or so miles. He was running between Baltimore and D.C. today and noticed that the truck was running strangely. It lacked a bit of power was making white smoke and sometimes black smoke. He described the throttle as spongy, etc. but no check engine light in fact, no idiot lights at all. He had a friend check codes and it was a p0404. I know what it stands for and I know that the 6.0's are known for EGR issues. I have read how to disconnect it, but will this fix the problem or just cover-up a symptom of another major issue?
__________________
__________________
-Jason PAA Member #3 " I'll stand up next to a mountain...and chop it down with the edge of my hand..."
I'll keep my freedom, my religion, my guns, and my money.
You can keep THE CHANGE.
Roadside Help Network Mods and Maintenance
  #2 (permalink)
Old 04-21-2008, 08:36 PM
HKusp's Avatar
Update, I was talking to him on the phone and misunderstood...he pulled up out front and I went out and looked. He DOES have a CEL and the guy who read the code cleared it, but it was back on. It smells really bad and idling it's mostly white smoke, if he puts it in gear and pulls any kind of load it is mostly black smoke. Did I mention it smells bad? Not like a diesel should smell. I unhooked the EGR and it didn't change a thing, still smelled bad and the same white smoke in park and mostly black smoke when in D and loaded up and lugging the motor a bit.
Any idea's?
__________________
  #3 (permalink)
Old 04-21-2008, 08:40 PM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE. npccpartsman is gaining momentum as a positive member of FTE.
Sounds like EGR valve AND cooler (white smoke). Unplugging it isn't going to help on that truck. He needs to take it to the dealer and let them repair it correctly. I can get you some good contacts in Md. for recommendations to get it repaired.
__________________
I BLEED RAZORBACK RED
  #4 (permalink)
Old 04-21-2008, 08:48 PM
bismic's Avatar
bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE.
I would also suggest strongly that you get them to change the oil cooler also (assuming npccpartsman is correct - which I would bet he is). A plugged oil cooler is a big problem that results in other big problems.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #5 (permalink)
Old 04-21-2008, 11:10 PM
HKusp's Avatar
Thanks guys. He is going to the dealership tomorrow.
I will let you know what they say.
__________________
  #6 (permalink)
Old 04-22-2008, 05:08 PM
HKusp's Avatar
According to the stealership, it was just that the EGR needed to get replaced. He is going to pick it up as I type this. Thanks for the input guys, I appreciate it.
__________________
  #7 (permalink)
Old 04-22-2008, 10:05 PM
doubledee715's Avatar
doubledee715 is starting off with a positive reputation.
I don't think an egr valve would cause white smoke. Sounds like typical procedure for a Dealership to cop out on the actual repair and instead toss a new valve in and call it good. I would suspect he is still going to have the issue.
__________________
David, 2003 f250 centennial edition, afe, arp, itp, innovative tunes, 4" straight pipe, dieselsite coolant filter, blocked off egr cooler, quadzilla commander w/pillar mount(pos), 4.5" lift, f350 rear blocks, bilstein 5100's, 20/9 kmc hoss, 35/12.5 toyo mt, tinted tail lights, 35% front window tint..
  #8 (permalink)
Old 04-22-2008, 10:50 PM
HKusp's Avatar
I went with him to pick it up. It smelled better and no smoke. I was suspicious as well, so we will see in a day or so I would imagine. If it acts up again, I will update y'all.
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
