front brake anf hub smokin hot!!
Old 04-21-2008, 04:00 PM
kdbbmanton's Avatar
kdbbmanton
kdbbmanton is offline
I have a 2004 F150 ext cab 4x4 with 106,000 miles. Saturday I was driving and I started to get a bad shimmy in the steering wheel. I could smell that the right front brake was hot! also the hub was so hot you didnt dare touch it! I was near a boat launch and drive the front into the lake and cooled everything down. If the caliper was stuck wouldnt it be pulling to the right? all it was doinf was shaking the steering wheel. I drove it home after cooling it down, anouther 30 miles and everything was fine. Sunday it was fine for 20 miles then it did it again....close to home this time..I let it cool down.jacked it up everything turned normally..tried removing the caliper but it was like welded to the back pad? I eneded up chipping both cylinders on the rotor...I am replacing the caliper tonight, bit am not sure if thats what it was??
Old 04-21-2008, 04:34 PM
BrianFX4's Avatar
BrianFX4
BrianFX4 is offline
I had the same type thing happen. The "Pin" or "Cylinder" in the caliber got hot and warped so it could not release the brake so the brake stayed semi engaged. Both front calibers had to be rebuilt.
Old 04-21-2008, 05:11 PM
mattd17's Avatar
mattd17
mattd17 is offline
could be that your slide pins are sticking also. much easier to fix if its the case.
Old 04-21-2008, 07:11 PM
t lindemann's Avatar
t lindemann
t lindemann is offline
I would go ahead and replace or have the rotor turned if the hub was too hot to touch then the rotor was probably glowing and when you drove it into the water it eather put tiny cracks in the rotor and definatly warped it.
Old 04-22-2008, 07:43 AM
kdbbmanton's Avatar
kdbbmanton
Thanks guys!!! I am putting on the new rotor tonight
Old 04-23-2008, 08:31 AM
Corey872's Avatar
Corey872
Corey872 is offline
I had a similar thing happen. The rubber seal around the caliper pistons failed and let the caliper rust. The rust flaked off and got wedged between the caliper and the pistons. Got hot enough to melt the plastic dog bowl hubcap off the wheel.
Old 05-06-2008, 08:39 AM
kdbbmanton's Avatar
kdbbmanton
the rotor was the problem...thx!
Old 05-11-2008, 08:56 PM
baitmaster's Avatar
baitmaster
baitmaster is offline
When backing my boat into the water, I usually let the wheels cool off for a few minutes while I'm getting everything ready for a day on the water. When you back a hot hub into the water, it can cool off too fast and suck water thru the seals if they are weak. (More true on the older vehicles I suppose). For this reason I usually pull my boat trailer wheels and clean and repack with marine grease once a season.
Old 05-12-2008, 09:13 PM
tomdoggie's Avatar
tomdoggie
tomdoggie is offline
It is not a good idea to drive a hot rotor into the lake. Im suprised it didn't crack.
Big_Al59
05-26-2017 06:28 PM
CollinsCD
1999 to 2016 Super Duty
15
03-31-2017 01:05 PM
agtech
Escape & Escape Hybrid
09-19-2016 08:11 PM
Firefighter 1406
02-26-2016 10:39 PM
waterbear
Aerostar
08-24-2013 03:10 PM
Quick Reply: front brake anf hub smokin hot!!
