Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-21-2008, 04:51 PM
Jay Banks is starting off with a positive reputation.
Air Intake
Hi,
Converted from Dodge to Ford and in the process of doing some mods.What do you all recommend for a Air Intake system, I thought I would start here first and then go with a 4 inch exhaust and then the Xcal2. Looking to get better MPG, without breaking the bank. Right now I get about 13-14mpg. I know the tires cut down a little bit, but hope to get maybe 16- 17. What do you all think?
  #2 (permalink)
Old 04-21-2008, 07:25 PM
FTE Sponsor
ToughBuiltFord is starting off with a positive reputation.
The ol' K&N is generally spoken well of...
__________________
Motorhaven powered by AutoAnything Auto Parts
Since 1979 - Equip Any Vehicle For Any Lifestyle
Use the coupon code FTEDEAL in our shopping cart and get $20 off orders over $199
Check out the AutoAnything blog for the latest news in the Automotive industry!
Got an Automotive Blog? List it here in the Auto Blog Directory!
  #3 (permalink)
Old 04-21-2008, 08:00 PM
ricg is starting off with a positive reputation.
IMO i would stay with the stock intake system....if you read more on the forums the truck seems to run better with it and the stock intake is good for like 400 hp or something like that but dont quote me....and if im wrong please somebody correct me....
__________________
2004 fx4 f250, all stock with a pro-comp 4in lift soon to have xcal2 and gauges.......wait scratch that i need a new motor
  #4 (permalink)
Old 04-21-2008, 08:02 PM
Momorris is starting off with a positive reputation.
The stock filter is the way to go. Save the turbo and stick with stock. I supports up to 500hp anyway. I don't think you will find many, maybe 1 in 100 on this site that recommend an intake.
__________________
2005 F250 KR CC 6.0L
DashDAQ - soon to be Phalanx Monitor
ARP headstuds
Silverline Turboback
SCT X3...Spartan and Innovative tunes
DFuser Coolant Filter
  #5 (permalink)
Old 04-21-2008, 08:18 PM
bismic's Avatar
bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE.
FROM FORD: 6.0L & 6.4L Power Stroke Diesel
Super Duty and Excursion Air Filtration Q&A
Q: Don't all filters stop the same amount of contaminants from getting into the engine and turbo?
A: Absolutely not! The 6.0L and 6.4L OE filters, produced by Donaldson Company, Inc., stop 99.99% of contaminants the size of one micron or larger. Some aftermarket filters trap only 95%. What does this mean to an owner? Driven in the same conditions, a 95% filter would pass 50 grams of contaminant through to the engine that would be trapped by the OE filters! Even a 99.00% filter would pass 10 grams of contaminant. This could mean an early end to your engine or turbo.
Q: Won't aftermarket airbox modifications, which use a lower priced filter, save me money?
A: Don't be fooled by aftermarket tactics of comparing the cost of one filter because you also need to know how often you'll need to change filters. The 6.0L and 6.4L OE filters hold more than three pounds of dust, dirt and soot. The aftermarket kits tested by Donaldson Company, Inc. held about half this amount. And don't forget, if these aftermarket replacement filters are less than 99.99% efficient, they pass some contaminant through to the engine that the OE filter would have stopped!
Q: How frequently do the 6.0L and 6.4L OE air filters need to be changed?
A: Everybody's driving habits and environments are different.
Owners/Dealers should check the air filter restriction gauge (located on the upper housing of the air cleaner assembly) at each oil change interval to determine when the filter needs to be changed. Some vehicles also have a dash light that will illuminate when the filter needs to be changed. No replacement is necessary until the filter minder (or dash light) gives indication.
Q: My filter minder doesn't seem to move, so shouldn't I check or change the filter to be safe?
A: The filter minder is a gauge that starts registering only after the filter reaches a certain point of being filled. This is why owners do not see it consistently move (like a gas gauge). Rest assured, the filter minder works and there is no reason to check on the filter by removing the airbox cover, thereby increasing the risk of contaminants entering the air intake system. Remember, the 6.0L and 6.4L OE air filters hold more than three pounds of contaminant – so it will take some time to fill!
Q: I want maximum airflow through the system to provide more power. Don't some aftermarket filters provide more airflow than the 6.0L or 6.4L OE air filters?
A: Airflow should not be the determining factor in buying a filter. Think about it: would you ever operate without a filter in place even though you'd get maximum air flow? High airflow generally means the filter is less efficient at stopping contaminants, too. Owners should instead look for the combination of three factors: airflow, how small of contaminant the filter will stop, and how much contaminant the filter will hold. The 6.0L and 6.4L OE filtration systems provide a great combination and it comes standard on all Super Duty and Excursion trucks!
Q: If the 6.0L and 6.4L OE filtration systems are so effective and efficient, why would anybody pay to modify them?
A: Excellent question. It makes no sense to pay hard earned money to go backwards in technology – especially considering that such modifications may even put future warranty repairs in jeopardy. You invested in your 6.0L or 6.4L Power Stroke Diesel truck to provide years of dependable service. Ford engineered it with a great filtration. So just why would anyone pay to modify it?
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
  #6 (permalink)
Old 04-22-2008, 07:01 AM
2003 Stroke is starting off with a positive reputation.
most would say as long as it is a progaurd 7 filter you should be fine...however, w/ that being said most would say you do not need one until you reach higher hp. i got one....seems to spool faster...you hear the turbo outside the truck more, but not sure it was worth the bill. jmo
__________________
2003 F250 6.0 PSD SB Lariat 4x4 4" superlift, 35 x 12.5 x 20 Toyo Open Country MTs on 20 x 10 American Racing - Chrome Cannons, Volant Ram Air Intake, Silverline 4" Turbo Back Exhaust, SCT tuned by SDT, ARP Head Studs, ISSPRO Gauges - Pyro, Trans, and Boost, Air Dog 100, ITP Reg. Return
  #7 (permalink)
Old 04-22-2008, 08:06 AM
Inzax is starting off with a positive reputation.
Being a noob and reading these forums for a couple of months I would NOT change the air intake.
When I first got my 05 back in 07 I had all sort of mod plans. The first two were an air intake and exhaust mod. The truck works fine and does everything I ask in its stock configuration. The 6.0's seem a little moody and I worry about the impact of mods. Others on this board have had great success with various aftermarket configurations. I am just urging caution. By asking your question here it looks like you are off to a good start.
Good luck.
  #8 (permalink)
Old 04-22-2008, 10:44 AM
Thanks for all the advise. I think I wiil stay with the stock intake. Does the 4 inch exhaust or the Xcal tuner make any sense?
Thanks
  #9 (permalink)
Old 04-22-2008, 10:48 AM
Definately, both great mods. You should also look at a good set of gauges. Boost (unless its newer than 05), trans temp, coolant temp, and egt are the most popular.
__________________
ARP headstuds
  #10 (permalink)
Old 04-22-2008, 12:38 PM
Thanks, its a 2006 and it has the Turbo PSI gauge.
  #11 (permalink)
Old 04-22-2008, 12:53 PM
RDJ184's Avatar
RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold RDJ184 is a splendid one to behold
my 06 has boost, trans temp, coolant temp all stock want a egt but one gauge would just not look right
__________________
JOIN NEW MEXICO CHAPTER HERE!
RANDY
OFFICIAL
怠け者, 兵役忌避者
Faulenzer
прогульщик
  #12 (permalink)
Old 04-22-2008, 01:12 PM
Stock?? My Turbo PSI gauge is with the RPM gauge at the bottom of it. I did not know you could get the gauges stock. Are they on the pillar?
  #13 (permalink)
Old 04-22-2008, 01:24 PM
RDJ184's Avatar
Quote:
all in the dash stock
__________________
RANDY
OFFICIAL
怠け者, 兵役忌避者
Faulenzer
прогульщик
  #14 (permalink)
Old 04-22-2008, 02:12 PM
If you tow or like to haul a**, you definately need better than the stock dumby gauges. Those usually don't warn you til it is too late.
rdj184, there are plenty of people with just one gauge and it doesnt look bad.
__________________
ARP headstuds
  #15 (permalink)
Old 04-22-2008, 02:18 PM
RDJ184's Avatar
What are you saying the gauges are not accurate.....d**n I never really thought about that I was just happy to have them
now I am going to be all stressed
__________________
RANDY
OFFICIAL
怠け者, 兵役忌避者
Faulenzer
прогульщик
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
