Go Back   Ford Truck Enthusiasts Forums > Diesel > 2010 4.4L Ford Diesel
2010 4.4L Ford Diesel Discuss the upcoming 4.4L Ford diesel engine
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-21-2008, 01:33 PM
bookem15 bookem15 is offline
bookem15 is starting off with a positive reputation.
MPG's vs HP/TRQ
I have been doing alot of reading and from what I see Ford should be able to make this diesel get 25 mpg and still have 250 hp with 500 ft lbs trq. Also with that they can leave the people that want HP and TRQ to buy it in the aftermarket so the rest of us get the MPG's. just my .02. Anyone have any thoughts on this I would like to hear them. Also does anyone have a link to some information on the exhaust and urea set up, I would like to read more on that.
p.s. 450 to 500 ft lbs of torque is 85-135 more than current, and the F150 is already more capable than the competition.
Thanks
__________________
Drive it like ya stole it !!!
1997 F150 xtra cab 3 door 4X4 104,000
Next truck
2009 F350 CC longbed 4X4
V10 or 6.4L still not sure
  #2 (permalink)
Old 04-21-2008, 02:08 PM
duffman77's Avatar
duffman77 duffman77 is offline
duffman77 is starting off with a positive reputation.
I wouldnt expect too much more than 100 ft-lb per liter of displacement.
  #3 (permalink)
Old 04-22-2008, 10:33 AM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
i heard 420Ilbs
  #4 (permalink)
Old 04-22-2008, 10:51 AM
I am ok with 420 ft lbs that is plenty. It only has 365 now and they call it the most capable. That is the very reason they should go after the economy.
__________________
Next truck
  #5 (permalink)
Old 04-24-2008, 06:40 AM
mnmwhit's Avatar
mnmwhit mnmwhit is offline
mnmwhit is starting off with a positive reputation.
There is no good reason you can't have MPG and HP and TQ.
Quote:
__________________
06 F-350, North Pole, Alaska
Brush Guard w/4 moose lites
Mobil-1 Turbo diesel truck oil
fuel filters every 10,000 miles
AstroStart auto start
98 gal Transfer flow tank
Rhino liner on the rockers
Wabasto-Blue heat
MBRP turbo back duels w/ no CAT
  #6 (permalink)
Old 04-24-2008, 01:44 PM
eatfish's Avatar
eatfish eatfish is offline
eatfish is starting off with a positive reputation.
I will never be able to afford one, but I would much rather see MPG increase if it means sacrificing power. I only need about 150 hp in a half ton. Give me 3/4 or 1 ton to do work.
__________________
Fillet and Release >-))))*>
  #7 (permalink)
Old 04-24-2008, 08:52 PM
ya thas about wat my 300 puts out but it can still pull some ***** i think 250 hp would be plenty of hp for any truck today
  #8 (permalink)
Old 04-25-2008, 12:00 PM
Lead Head Lead Head is online now
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
You can have torque and HP and still get good mileage, which is why the 505HP corvette can still pull off 25-28 MPG highway. The main thing that decides mileage is the aerodynamics of the truck - during highway driving. For city driving, its how much the vehicle weighs.
Theoretically, a 500HP and a 250HP engine in the same truck, assuming both engines weighed the same, should get the same mileage, as long as they are both accelerating, traveling, etc.. at the same speed
  #9 (permalink)
Old 04-25-2008, 04:09 PM
BLK94F150 BLK94F150 is offline
BLK94F150 has a very good reputation on FTE. BLK94F150 has a very good reputation on FTE. BLK94F150 has a very good reputation on FTE. BLK94F150 has a very good reputation on FTE.
Quote:
I highly doubt that 150hp would please anyone in a 1/2 ton.
Mike
__________________
Confusing people's opinions with facts here since 09-30-2002
  #10 (permalink)
Old 04-27-2008, 09:02 PM
im happy with my truck,but like i said earlier a truck doesnt need anymore than 250hp
  #11 (permalink)
Old 04-27-2008, 09:19 PM
Quote:
Maybe so, but I like as much power as I can get. What I see the real problem being is excess weight. Weight will kill MPGs much faster than more power. You can always just get out of the throttle.
For example in the F150, cut the fully boxed frame. It's not needed other than for marketing. I have no idea how much weight it adds, but I'm sure it's hundreds of pounds. I have never once in any of my C-channel trucks, (from a Ranger up to an 80,000lb ladder truck) thought man this thing really needs more frame.
Mike
__________________
  #12 (permalink)
Old 04-27-2008, 09:48 PM
i agree with you completely.these trucks are just way too damn big.i cant count how many times ive heard people say the f150 need sto lose 1500 ilbs,but it needs to happen
  #13 (permalink)
Old 05-11-2008, 07:11 PM
Capt17 Capt17 is offline
Capt17 is starting off with a positive reputation.
I would love to see HP, torque and economy. But, it'll never happen. As long as the EPA has their fingers in it, you might as well forget the economy thing. My 6.4 Liter has more torque and HP than you would ever need, and prior to going into the "regen" mode, it will get about 18-20 MPG on the freeway. As soon as it senses the restriction in the particulate filter, it starts dumping diesel fuel down the exhaust, so it can "clean the filter" out. For an 8200# truck to get 18-20 MPG, especially when it has the aerodynamics of a brick, I don't think that's too bad. Then, when the Feds "make it environmentally friendly", it takes the fun factor clear out of it.
By the way, it's across the board from what I hear. Ford, Chevy & Dodge are all having the same issues with the DPF and fuel mileage.
  #14 (permalink)
Old 05-11-2008, 10:12 PM
spence13e's Avatar
spence13e spence13e is offline
spence13e is starting off with a positive reputation.
Quote:
Mike
i dunno, i'd be a little on the fence on that one. i had a REALLY light 95 3/4T w/ a 351 (rated at 205HP and maybe 300ft/lbs) geared with 3.55s. it did alright empty but i hooked it on the trailer a few times and it HATED pulling that thing. i wouldn't think that 200 +/- hp would be too bad with 350 to 400 ft/lbs. YMMV.
__________________
Ryan
2004 F-250 6spd Crew Cab 4x4
Built 09/03, 3.73LS, B&W Turnover Ball
K&N Cold Air Intake, Magnaflow 4" Cat Back
  #15 (permalink)
Old 05-12-2008, 10:58 AM
exactly it not hp that moves the trailer its torque
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
