Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #61 (permalink)
Old 06-17-2008, 02:16 PM
DanielsSoot DanielsSoot is offline
DanielsSoot is starting off with a positive reputation.
The specs say 20% better than the gasser which is around 16mpg so the new diesel should get 19ish mpg, right?
I think they should cut that motor in half, slap a turbo on it and put it in the Ranger and even in the F150 as a replacement for those in-line sixes they used to sell to make EPA numbers.
  #62 (permalink)
Old 06-17-2008, 02:41 PM
hsfbfan hsfbfan is offline
hsfbfan is starting off with a positive reputation.
If I'm not mistaken the '08 f150 with the 5.4L are EPA rated at 18 MPG on the Highway. A 20% increase on that would be a rating of almost 22 MPG.
I'd be that Ford is saying that the 20% increase is on the 2009 numbers. With the new transmission, I bet the '09 rating will be anywhere from 20 - 22, which would put the diesel rating at about 24 - 26 MPG.
__________________
1988 F-150 XLT 4x4
Manual Hubs
5.8L Automatic
  #63 (permalink)
Old 06-26-2008, 11:50 AM
Fosters Fosters is offline
Fosters is starting off with a positive reputation.
I couldn't agree more with Kel and Lead Head.
To the example with the 2 trucks, the gasser versus the dizzle, both geared the same and the gasser not being able to carry the same load. Here's why:
Your gasser can obtain a certain speed in any given gear, lets make it 50mph per each gear for the ease of argument. That means it can use it's entire rev range to move 50mph in 1st gear. The diesel, same power, can only move 30mph in the same gear, even though, it too is using it's entire rev range.
Basically, what that says is, the gasser's power is spread across a larger spectrum, a longer powerband, that needs to be made up for with gears - and that's what these guys have been saying all along.
Gear that 460 with some 5.88 gears, make it so it obtains the same speeds in each gear as the diesel, and you will see it tow the same exact load at the same exact speed.
The tall man and the short stocky guy example is great. on the 8000 hp and 50 torque example; that sounds like a jet engine . There are plenty of jet dragsters that accomplish the same thing as their nitro methane burning counterparts. They do have insane gearing on their side though if they're going to be used to move something attached to them; aka not by moving large amounts of air. To give you an example of this, here's a snippet on the chrysler turbine concept of the 60s:
Chrysler Turbine
THE TURBINE - An Alternative to the conventioal engine
the engine revved to 50,000 rpm almost, and used, in addition to the transmission gears and rear end gears, a reduction gear of 10:1 ratio, which turned the relatively low torque of the engine, into a much more useable and very respectable 425lbft of torque at a 4250ish rpm.
your 8000hp = (50tq * rpm) / 5252 equation would indicate the rpm would have to be:
8000 * 5252 = 42016000
42016000 / 50 = 840320 rpm.
that's well above even a jet engine, but that's about as close as you'll get to that . If indeed such an engine existed, it would be ridiculously powerful. Imagine putting 200:1 gears on that thing. Torque would get multiplied by 200, while rpm divided by 200. 50*200 = 10000lb ft of torque, and the rpm would be a more respctable ~4200 (still high for a truck, but it would be more down to normal useable rpms that we can use here on earth.
I'd say that engine could tow it's fair share... wouldn't you?
__________________
2000 Excursion Limited 4x4 V10 - soon to not be stock anymore.
2004 F150 XLT screw 4x4 5.4 - 2.5 leveling kit, 34.5" BFGs - Gone
2004 mach1 mustang, holding the garage floor in place.
  #64 (permalink)
Old 07-18-2008, 01:37 PM
Red2003XLT Red2003XLT is offline
Red2003XLT is starting off with a positive reputation.
I'll wager Ford detuned the 4.4 in order to satifiy both legal and warrenty departments.
At least the aftermarket will fix the management overslight.
__________________
Ranger 2003 XLT 3.0 V6 auto Pure stock 24,000 miles
  #65 (permalink)
Old 07-21-2008, 01:13 PM
it'll definitely be interesting to see what kind of MPG and power the thing will be able to get with all the emissions restrictive crap removed...
__________________
  #66 (permalink)
Old 07-23-2008, 05:04 PM
clawhammer clawhammer is offline
clawhammer is starting off with a positive reputation.
ok. so dont get mad at me if im wrong but one thing i havent noticed anybody mention is where the power is placed. in order to get a gasser to put the torque at a usable range it would have to be geared much lower, thus eating up the speed it may have. if a vehicle has 8000hp its power will most likely be placed in a completely unusable range, which is why i believe that diesles are often prefered for towing because of the power placement, not nessesarily the amount of power
also dont chew me out if im wrong here but it was once explained to me that torque (more or less) is how much work can be done and HP is how fast you can do said work.
that is just my 2 cents
P.S. im not taking any sides on this whole HP vs TORQUE argument going on
  #67 (permalink)
Old 07-23-2008, 07:18 PM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
ur pretty much right
  #68 (permalink)
Old 07-23-2008, 08:14 PM
jroehl jroehl is offline
jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of
Quote:
You have to be careful with your terminology, though. Torque is a force, and "work" is actually a separate, defined concept in physics--force applied over a distance. HP is how fast you can apply torque. Like I said in a previous post, I could put a 5' cheater bar on a wheel, lift up with 100 lbs of force, and I'd be applying 500 ft-lbs of torque to the wheel. But, that would be at a very low horsepower...
Jason
__________________
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
The government cannot give to anybody anything that the government does not first take from somebody else.
http://folding.extremeoverclocking.c...e.php?u=402948
  #69 (permalink)
Old 07-24-2008, 05:38 PM
anyone kno how many humans it would take to equal one hp
  #70 (permalink)
Old 07-24-2008, 05:48 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
Quote:
1 for brief periods of time, i think its something like .3-.4 HP continuous.
Odly, a horse can peak at 16HP
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #71 (permalink)
Old 07-25-2008, 12:38 PM
We did try back in phoenix to get a person dyno'd. Ran into a snag when trying to find something to attach the cable to sense RPMs tho. Mustang club dyno day - buncha rednecks with a dyno and some beer around...
__________________
  #72 (permalink)
Old 07-25-2008, 12:51 PM
Quote:
Next time you do that, bring a bicycle, that should give you something to sense RPM
__________________
- Ian
  #73 (permalink)
Old 07-25-2008, 04:32 PM
secondarychaos's Avatar
secondarychaos secondarychaos is offline
secondarychaos is starting off with a positive reputation.
Quote:
That's exactly right.
The problem with the towing debate is that you cant separate HP and TQ, they are always connected through that formula.
Diesels seem easier to tow with because of their lower revving engines.
Because of the RPM range of diesels, they do tend to be slightly better geared.
They also have a higher thermal efficiency (meaning better MPG, especially with towing. )
But, In my Opinion, Diesels do have some major advantages in towing-
First, their torque is stronger and more constant, so, a diesel engine is doing more work (maintaining a higher AVERAGE HP)
The other is the turbocharger. When i'm towing 10-12k lbs of firewood on a 1500lb trailer in the mountains, My turbo will spool, and if the RPMs dont build, the turbo will produce more and more boost. (to a point)
My dad and i were running up to our camp spot with a 12k lb fifth wheel, and he hit 31lbs of boost on a nearly stock truck. (intake and exhaust)
That boost made a world of difference (especially on a 7k' mountain pass!)
So, IMO, a diesel is better for towing, but not for the TQ, just for the overall performance, and the better fuel mileage.
__________________
96 powerstroke
Tuned by Power hungry
  #74 (permalink)
Old 08-15-2008, 04:46 PM
cartmanea cartmanea is offline
cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE. cartmanea has a good reputation on FTE.
For some reason I thought the 4.4L was going to be a V6 like the current 4.5L.
__________________
2003 F250 FX4 Sport, 6.0L Diesel, TorqShift Auto
- 4" Donahoe Racing springs, Bilstein shocks,
4.30 Yukon gears, Detroit TrueTrac
- 18x10 Diamo 17 Karats, Cooper STT 35x12.50,
Off Road Tech winch bumper
- SCT Xcal2 with Spartan tunes, ISSPRO EV2 Gauges (Pyro, Fuel PSI, Boost)
  #75 (permalink)
Old 08-18-2008, 10:37 PM
Quote:
it should be less cylinders,less problems
__________________
92 F-150 300I6/M5OD/3.08/64k
77 F-150 302/V8/3.55/224k
88 Chevy2500/350/4.11/179k
98 F-150 4.6/3.55/112k(sold)
Tags
2011 , 64 , f350 , hp , mpg , pulling , restriction , torque , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
