Go Back   Ford Truck Enthusiasts Forums > Diesel > 4.4L Ford Diesel
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
4.4L Ford Diesel Discuss the much rumored 4.4L Ford diesel engine
Is F-150 Still King?
  #46 (permalink)
Old 06-11-2008, 11:17 AM
KelVarnson KelVarnson is online now
KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE. KelVarnson has a great reputation on FTE.
Quote:
Originally Posted by mudmaker View Post
I guess what you are saying is with gearing you can make torque equal between two motors that have the same hp.
Yes... ...rear-wheel torque, at a given speed. And if they have the same rear-wheel torque, and are moving the same speed, they have the same HP, and thus can pull the same load. The gasser might be screaming to do it, but if the engine HP is truly the same as the diesel HP, it will move the same load.
It is all how you word it. I see what you are saying and everything, but I guess the question should be how much hp is needed. The real answer is much lower than most would think. Even if you dont want monster low gears, that is as long as your make some good torque #s. I think a 200 hp/400lb tq in a 1/2 ton would be great. I dont know the #s they are looking at, but I know the early psd is a great motor pulling heavy loads even with 3.55 rearends, so if a 1/2 ton had similar #s it would be a great little runner.
Agreed. I bought my 7.3 because I thought it would tow better than my GMC. I was disappointed. Don't get me wrong, I'd still MUCH rather tow with the Ford, it is a much more pleasant experience overall. But I was surprised that the GMC would tow the same load up the same hill at a higher speed, that is, I was suprised until I really took a close look at the HP vs. torque relationship. Then I understood. The math clearly supported the difference in performance between the two trucks.
__________________
'02 F250 SCLB 7.3 4WD, 105k. 6637 Filter, JW Valve Body, 6.0 Trans Cooler, 285/75 16 Michelin LTX-AT2's, Line-X, Snug-Top Shell, Yakima Racks.
  #47 (permalink)
Old 06-11-2008, 02:49 PM
tjthegreat tjthegreat is offline
tjthegreat is starting off with a positive reputation.
a diesel will get a bigger load moving than a gasser,if you have an equal hp gasser it will hold speed just as good as a diesle would,although the diesel will get a much bigger load moving that a gasser couldnt handle,after you are cruisin thats where the hp takes over
  #48 (permalink)
Old 06-11-2008, 06:16 PM
Quote:
Generalizations like that are not supported by the physics. IF the gas motor has the same HP as the diesel, and IF the gearing is correct to get the gas motor to its HP peak, then the gas motor will be able to generate the same rear-wheel torque as the diesel, and it is the rear-wheel torque that causes the load to move.
In practice, it might SEEM like diesels have the edge, because they do have more low-end grunt. It feels like they're not working as hard, because they are not turning as fast. People don't like to wind out gassers the way they would have to to get equivalent rear-wheel torque; they're afraid they're overworking the motor, or they just don't like the sound of it. But if they did, they'd find that the 250 HP gasser is just as capable as the 250 HP diesel.
Same power, different RPM, but geared differently to result in the same rear-wheel torque. That's all there is to it. Go back and look at the formula I posted before. There is no way around that. You can't get something for nothing.
__________________
  #49 (permalink)
Old 06-11-2008, 06:51 PM
irishammer irishammer is offline
irishammer is starting off with a positive reputation.
My favorite quote I saw was....HP is how fast you hit the wall.....Torque is how far you push the wall after you hit it!
  #50 (permalink)
Old 06-11-2008, 08:10 PM
Lead Head Lead Head is offline
Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE. Lead Head has a good reputation on FTE.
A 300HP gasser with 250 ft-lbs, and a 300HP diesel with 800 ft-lbs will get the same load moving at the same speed at the same time, IF the gearing on each engine is setup properly
__________________
- Ian
1987 Ford Ranger XLT 4x4 2.9
Needs a lot of work, including some rot on the body, but shes getting there.
  #51 (permalink)
Old 06-11-2008, 08:20 PM
i get what your saying, but a diesel engine is a better choice because they do put out more torque....stock,if you hopped up a gasser to match the torque of a diesel,the gasser would probably pull more because it would most likely have more hp,but you cant find a gasser that puts out the torque of a diesel from a dealer,and most people wouldnt want to spend all of that money for mods on their gasser,which is why people will most likely buy the diesel
  #52 (permalink)
Old 06-11-2008, 08:21 PM
BigF350 BigF350 is offline
BigF350 is starting off with a positive reputation.
So if you gear the gasser right then you will be able to do the same work as the Diesel??? Right..
  #53 (permalink)
Old 06-11-2008, 08:47 PM
Well, to be fair, diesels cost more to start with, but I do agree with what you are saying. Besides, even though the gasser might be as capable, it would never be as econmical, or as nice to tow with.
__________________
  #54 (permalink)
Old 06-11-2008, 09:29 PM
If the HP is matched, they can both pull the same amount. But you will have to wind out the gasser alot more then the diesel, making it more pleasant to tow with the diesel
__________________
- Ian
  #55 (permalink)
Old 06-16-2008, 05:23 PM
jroehl jroehl is offline
jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of jroehl has much to be proud of
You guys are really missing the physics on the whole HP vs. Torque debate. Torque is a measure of rotational force. HP is a measurement of work performed--think in terms of torque applied over a period of time or energy used. In other words, HP has an additional factor of time included in its units.
A vehicle at a constant speed on the highway is at an equilibrium--the torque produced by the engine is matching the sum of the frictional driveline losses, wind resistance plus rolling resistance--which are all forces as well. HP is an indicator of how quickly the engine can apply its torque.
Two engines of the same max torque will be able to move the same maximum load. The one with the higher max horsepower will do it more quickly.
Diesels tend to be better at pulling because of the way the fuel burns--more slowly, so the force on the piston is applied longer, allowing for more overlap (or less gap) with the next cylinder that fires. Gasoline burns quickly, which is why it does better at higher engine speeds.
Jason
__________________
-1993 F250 XLT xcab LB 351 2wd E4OD 4.10 open (parked, tranny issues)
The government cannot give to anybody anything that the government does not first take from somebody else.
http://folding.extremeoverclocking.c...e.php?u=402948
  #56 (permalink)
Old 06-16-2008, 06:17 PM
Quote:
The HP calculation does not include time, only torque and velocity. HP is not a measure of energy, it is a measure of instantaneous power.
Yes, but in a typical gas vs. diesel comparison, for matching loads and vehicle speeds, the engine torque being generated by a gas engine is much less than that of a diesel, BUT, the engine speed is a lot higher. So you can't just use engine torque alone for a comparison. You have to look at both engine torque and engine speed together, if you want a useful indicator of capability.
That is not necessarily true, unless they happen to make that same torque at the same speed (i.e., they have the same HP).
That is true.
__________________
  #57 (permalink)
Old 06-16-2008, 07:00 PM
Quote:
1 HP = 33,000 ft-lbs/min. Ft-lbs is a measure of torque (rotational force, which includes distance). 1/min is a time factor. It doesn't get any simpler than that. Read up here: Horsepower - Wikipedia, the free encyclopedia and Torque - Wikipedia, the free encyclopedia "Power is the work per unit time."
Sorry, but you're way off on this one. Take the example of a breaker bar vs. an impact wrench. With a long enough breaker bar, I can put 500 ft-lbs of torque on a nut. So can a decent impact wrench. But it will spin it much faster--because it has more HP. That is why I emphasized that HP includes the time factor.
Quote:
That is true.
At least we agree on something.
Jason
__________________
  #58 (permalink)
Old 06-16-2008, 09:36 PM
Oh, right. Time is taken into account with the RPM. But HP is still not a measure of energy, it is a measure of power.
And when you say, "Ft-lbs is a measure of torque (rotational force, which includes distance)", what do you mean by "which includes distance"?
Re-read the above three posts, and you may see that I misunderstood you initially. I thought you were speaking in general terms, saying that two trucks with the same torque rating would be capable of towing the same load at the same rate. I believe now that you were talking about the engines alone, and how much force they could generate.
And based on your breaker bar vs. impact wrench analogy, it's clear that you understand that it takes more horsepower to apply a given force faster.
__________________
  #59 (permalink)
Old 06-16-2008, 11:03 PM
I probably shouldn't have said, "which includes distance", because now that I re-read it, one could think that I was implying a travel distance, when what I was referring to was the radius of the torque.
And, yes, when I was speaking of getting the same maximum load moving with two identical-torque/different-HP engines, I mean all else being equal, the higher HP engine will move it faster.
I think we're pretty close to being on the same page here...
Jason
__________________
  #60 (permalink)
Old 06-16-2008, 11:24 PM
Jason
Excellent, I think we are. Thanks for clarifying, and for making me think about it.
__________________
Tags
2011 , 64 , f350 , hp , mpg , pulling , restriction , torque , truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
