Join Our Site - Its free, quick and easy!
Click Here to join.
04-21-2008, 01:27 PM
Bronco Hemi Swap
How hard would it be to swap a early 354-392 Hemi in to a 1980-1991 Bronco?
Thanks
Shrtbed
__________________
1968 F100 Flareside- Currently being restored
2007 Mustang- Currently being beat into the ground
[QUOTE
At which point we'll all want to come over and use your stuff.
Bah. You can get good enough results from five gallons of bondo and a six pack.
][/quote]
04-21-2008, 01:49 PM
If you have to ask this question, it's going to be really hard.
Do you weld? Do weld well? Do weld 1/4" thickness steel well?
Are your investments yielding in such a fashion as to provide a steady stream of cash well in excess of your needs?
Are you good at fabrication?
Are you going to run the stock engine or is it sporting a 6-71?
Are you just repowering or are you building a racer?
Do you have access to hoists, jacks, clean & safe place to work?
04-21-2008, 03:39 PM
I weld.
I weld O.K.
If I did it I would borrow a better welder and a freind who welds better.
I am good at fab and "redneck engineering" and know people who could help.
It would be a stock rebuilt 392.
It would be a neat street cruiser with the occasional mud bog.
I am pretty much looking for ideas.
__________________
[QUOTE
][/quote]
04-21-2008, 11:58 PM
Do you have a stock rebuilt 392 Chrysler Hemi from the 1950s?
04-22-2008, 12:09 PM
I do not. I am intending to find one and do the swap when time and funds allow. I'm not expecting this to be cheap or easy either.
__________________
[QUOTE
][/quote]
04-22-2008, 04:03 PM
Well, it won't be cheap or easy. A lot of 354s and 392s got used up drag racing. Remaining units are prized by the restoration crowd. You can find an air raid siren with a 331 in it, but good luck making power with that.
These babys, even the 331, weigh over 700 lbs. The highest stock hp for the 392 with 2 4bbl was 390 horse, gross hp and so that translates to about 312 hp net.
If you build it stock--what's the point? If you are going to take advantage of that 700lbs and make a fire breather, well, shall we say, more power to you.
You'll be on the road faster, going faster, with a fatter wallet, if you build a 400 with a straight up cam, some compression and a decent intake and headers.
Chrysler Corporation Early Hemi Engines
Good luck.
04-22-2008, 04:10 PM
Thanks for the info I will take that into consederation. I might go with a 440 Mopar.
__________________
[QUOTE
][/quote]
04-22-2008, 10:16 PM
Funny thing is, i know where there is an almost complete 331 hemi and a Complete 50's Dodge truck hemi siting in the woods. i wish I could have them. I doubt the owner would hook me up.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
A bunch of motorcycles, other cars, and a Quad.
04-24-2008, 07:46 PM
All you can do is ask. You already got the 'stang!
__________________
[QUOTE
][/quote]
04-26-2008, 10:27 AM
why not just a 460/429 or FE.
__________________
04-26-2008, 12:05 PM
Quote:
Originally Posted by
JBradley500
I will probably end up doing that. I might swap in 352 though, because a buddy of mine has 2 that I could get for cheap.
__________________
[QUOTE
][/quote]
04-26-2008, 12:12 PM
A stock 352? All that work--not a stock motor, no no no.
04-26-2008, 01:43 PM
How about a 347 stroker? Would that make everyone happy? At least I didn't sugest a SBC! Oh and one of the 352's is all worked over bottom end, cam, heads,intake etc.
__________________
[QUOTE
][/quote]
04-28-2008, 12:04 AM
04-28-2008, 05:35 AM
Nothing. I know a guy that beats them to death in the mud, takes the engine/trans. out then leaves them to rot.
__________________
[QUOTE
][/quote]
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is On
