302 head porting
302 head porting
I just got a 68 302 that i am putting together. The short block is all finished it is stock. The heads are where done by a local machine shop and they are all stock too. My question is should I do any work on the ports? I have a machine shop not an automotive machine shop but I have a CNC and a manual mills. But I have no idea how to port the heads. I could easily match the gaskets or headers but would I gain anything by grinding/machining these bumps out of the exhaust ports?
Also would be really easy for me to put threaded rocker arm studs in would it be worth it? What about push rod guide plates? Looks like they would be cheap and easy for me to do but would I gain anything?
Any suggestions on a cam?
302 head porting
Definately grind the smog bumps off in the exhaust ports. Port matching and bowl blending will also make a big difference.
Here's a couple of web sites that give good explainations on how to do a quality port job:
http://www.sa-motorsports.com/diyport.htm
http://www.fordmuscle.com/archives/2000/07/homeporting/index.shtml
There's another good one too but I can't find it in my bookmarks.
RCC
RCC
RacinNdrummin
02-24-2015 04:24 PM
william16339
07-15-2014 11:52 AM
william16339
07-15-2014 08:41 AM
79wisc.roadmonster
26
02-12-2014 08:45 AM
