Go Back   Ford Truck Enthusiasts Forums > Diesel > 2003 - 2007 6.0L Power Stroke Diesel
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
2003 - 2007 6.0L Power Stroke Diesel SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-21-2008, 10:05 AM
fordboy2 is starting off with a positive reputation.
long crank time/hard start kinda!
Lately I have been noticing a longer than normal crank time when the truck is cold. THe weather is about 40-50 degrees outside. Normal crank time I would guess to be 2-4 seconds and this would be about 10-15 maybe even a little more a couple of times. Looking for suggestions on what to check, I am thinking maybe the glow plug relay module located on the passenger valve cover. Could it be a glow plug? The truck is in my sig below, thanks in advance for any help, Aaron
__________________
06 f350 lariat srw-factory 20's(winter), mb shakers w/35" toyo mt's(summer), chrome package,zoodad, pioneer D3 with rear monitor,riderite air bags, sky jacker leveling kit, air lift air bags in front, 8.2 Boss v-plow, 90 watt corner strobes, 4" magnaflow turbo back exhaust minus the kitty, K&N fipk, coming soon spartan tunes, analog gauges
  #2 (permalink)
Old 04-21-2008, 12:33 PM
BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE. BowTieHatr has a very good reputation on FTE.
do you have the latest reprogram?
__________________
To whom it may concern;
Ford Senior Master Tech since '05
ASE Master Tech '04
6.0ing since '03.
6.4ing IF they tear up
  #3 (permalink)
Old 04-21-2008, 02:31 PM
THe truck was updated last fall in around oct.
__________________
  #4 (permalink)
Old 04-21-2008, 05:43 PM
Living Proof is starting off with a positive reputation.
Mine was doing the same thing and I replaced the batteries, maybe you have a bad battery? just a suggestion.
  #5 (permalink)
Old 04-21-2008, 10:08 PM
both batteries were new in december, not to say that may not be it but it cranks fine, just does not fire right away.
__________________
  #6 (permalink)
Old 04-22-2008, 12:57 AM
caycebugs is starting off with a positive reputation.
My 05 F250 was doing that last year. My dealer reflashed it and I have had no more problems. With the new flash, the injectors cycle for 30 seconds after switching the engine off. If yours does not cycle, you can definately hear it, you may need reflashed.
  #7 (permalink)
Old 04-22-2008, 08:47 AM
I will check on if the injectors cycle, how much to have a reflash done? This morning it was about 60some degrees and it fired right up.
__________________
  #8 (permalink)
Old 04-22-2008, 09:39 AM
69cj is starting off with a positive reputation.
To Caycabugs,
You do not have the latest flash. The latest is the induction flash and it also varies the turbo and shuts down the egr during extended idling.
__________________
"05 F-250, CC, LB, 3.73, Lariet, with coolant filter and Bilstein shocks, S. Ca.
"69 Mustang, Mach 1, 428 CJ, Ram Air, Stock
"71 Triumph Trident
2007 Thor Jazz 5er, 11k, 31'
  #9 (permalink)
Old 04-22-2008, 10:05 AM
could I have the latest flash since mine was updated in oct of 07?
__________________
  #10 (permalink)
Old 04-22-2008, 11:52 PM
hott-rodd is starting off with a positive reputation.
Are you guys still getting low power and poor fuel mpg from the new flashes?
__________________
2005 F350 2WD SRW LB , with 200,000 miles and rolling. Studs, SCT and 4" silverline Turbo Back .
2000 f250 2wd , fuel in-tank and pre-pump mod, 6637 filter , SS HPX, Dp 80hp tune, 5" cannon .RIP!
  #11 (permalink)
Old 04-23-2008, 07:28 PM
DStairs is starting off with a positive reputation.
Long crank time
I just bought my 06 f250. It had a bad injector and I had it fixed. It still takes quite a while to fire up. It cranks fine, just takes a while to start. I live in central Ca. so the climate is not the issue.
  #12 (permalink)
Old 04-23-2008, 09:00 PM
bismic's Avatar
bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE. bismic has a very good reputation on FTE.
Quote:
EDIT - 69CJ has this covered (I missed it in the first pass).
The new flashes are GREAT in my opinion. My mileage improved as far as I can tell. The only thing I have not heard is whether or not the 03's lose power from the flash. This was a definite complaint from previous flash updates.
Oct 07 flash probably included the Inductive Heating. If it didn't, you would hear the "buzz" of the injectors cycling (per caycebugs post) from the previous version flash.
__________________
Mark
06 F250 CC SB ESOF FX4 Lariat 3.73LS 275/65R20
DieselSite Coolant Filter; High Idle Mod
Zoodad/Air Fury grill; Accufab Elbow; CCV filter
Fumoto; HFCM Plug; Harpooned fuel tank
JimmiJammers; Ravelco; DashDaq & britebox on deck
Line-X, CPOhighway Prod. tool box, tracrac
Fox Weatherboots; Wet Okole Seat Covers
Stanadyne Perf. & B2 for lubricity
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
