Quote:
Originally Posted by RaleighDad66
My problem is the stuck solenoid. I have had two instances in the past 4 months where after starting, the solenoid sticks and the starter continues to crank. After pulling the negative cable out of the terminal, I promptly replace the solenoid (and battery cable) and life is good again. I even dissected one to verify the fused contacts.
Does any one know of a heavier contact solenoid I can use that looks period correct and wont burn my truck to the ground? I actually saw that happen once.
The problem is with the
quality of the auto parts sold today.
Most of the chain stores autoparts come from C-H-I-N-A, and are C-R-A-P.
Look for one made in the US of A.
NC: Give Dennis Carpenter a call, mebbe he has some GEN-U-INE FORD ORIGINALS. / EDIT: Green Sales has 10 = 800-543-4959
B6AZ-11450-A .. Starter Solenoid (Motorcraft SW-3) ~ Fits 1956/79 all cars & trucks.
1956/67 = marked FoMoCo in script on the metal bracket. In demand because these are correct for early Mustangs, HiPo Galaxies, '56/57 Birds, other collector cars / 1968 and later = marked FORD on the bracket.
