Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-20-2008, 11:23 PM
ErrorS is starting off with a positive reputation.
Putting a spool/welding my front diff? D44
I have a question, what reason is there to NOT do this? I couldn't afford a selectible locker for my rear at the moment and didn't want a spool, the truck needs to be somewhat drivable on-road.
But what negatives are there with spooling/welding the front? I'll only ever use 4wd offroad so it shouldn't be an issue. Is it hard to do? Can the D44 not handle it? what's the downsides to it? I'm about the change the front seals and i'm going to have my diff out anyways.
I hope I'm not being an idiot, I'm just now digging into the frontend of my truck for the first time.
__________________
1978 - F150. 4x4. 400. c6.
  #2 (permalink)
Old 04-21-2008, 12:42 AM
captain p4's Avatar
I'll sleep when I'm dead
captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold captain p4 is a splendid one to behold
what size tires you runnin? expect carnage probably with 35s, definitely with anything over that. There is the option of leaving one side unlocked though for turning.. but crawling through mud or whatever to lock it in when you're stuck won't be very fun
__________________
-Paul
86 Rustang 5.0/5spd.. and full of bootyfab.
78 Bronco 400 c6 np205 d60/sterling10.25
OBA, 36" hummer tires, some other stuff
2003 F350 Supercab shortbed FX4 6.0 PSD
  #3 (permalink)
Old 04-21-2008, 01:31 AM
Will turning be really bad even offroad? not that steering is easy in 4WD anyways but I can't have it useless.
I have 31s at the moment but I'm keeping an eye out for a good deal on 33s. if I can ever afford to run 35s my truck will be properly set up all the way around, selectable in front/rear, lower gearing, etc.
__________________
  #4 (permalink)
Old 04-21-2008, 02:00 AM
RawPower's Avatar
RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE. RawPower has a very good reputation on FTE.
Steering won't be horrible, but will be worse.
Just weld it & run it and when you break it, get a D60.
__________________
1993 F350 7.3 IDI, ZF S5-42, TS Div205, OEM/welded Rock's, 46's, 145" wheelbase
  #5 (permalink)
Old 04-21-2008, 07:00 AM
fishmanndotcom's Avatar
fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE. fishmanndotcom has a great reputation on FTE.
YUP! agreed
-cutts-
__________________
Quote:
Originally Posted by Ingolf View Post
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
  #6 (permalink)
Old 04-21-2008, 07:16 AM
quadzjr's Avatar
just another Rockwell looser
quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE. quadzjr has a great reputation on FTE.
dont do it.....turns like chit, will increase you chance for shaft breakage......
id recommend a cheap LS b4 welding it..........
__________________
Nick
: Sergeant at Arms
The Rockwell/4-link/anything Badass Specialist!
Dont be a puss, RUN ROCKS!!!!
Quote:
Originally Posted by Ebay Assjack View Post
The truck was lifted with the custom frame as seen in pix. (the best way to lift a truck!!!)
My Build: 96' f150 4link 2.5 tons etc etc etc....
  #7 (permalink)
Old 04-21-2008, 09:19 AM
Ryan50hrl's Avatar
Ryan50hrl has a good reputation on FTE. Ryan50hrl has a good reputation on FTE. Ryan50hrl has a good reputation on FTE.
X2 on the Limited slip....much better
__________________
2007 Lariat screw - tri coat met - chrome package - Black leather captains chairs - sunroof - audiophile
2005 XLT scab -
1995 xlt scab - 13 inches of lift - SAS
  #8 (permalink)
Old 04-21-2008, 12:27 PM
chrono4's Avatar
chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all chrono4 is a name known to all
Everyone has thier own views on spooling a 44. If you never plan on getting big tires or alot of power, and don't mind not being able to turn the best, then do it. But then again, a ls or cheap locker isn't really that much for a 44, and I think you would like it alot more, and you would be able to turn and have less breakage.
__________________
--Andrew--
Rocking a 79' f150 with a 300 and a 4 speed........
Full York OBA Install
Welding a 9"
Very simple front bumper
Lowering Spring Towers
Hi, I'm Andrew and I have a wheelin problem that is often disrupted by fabbin and drinkin, glad to meet yall.
Technical Advisor
  #9 (permalink)
Old 04-21-2008, 03:33 PM
I can't even find a D44 LS, eBay is just about useless anymore..
I think I've asked this before but can I use the same locker/LS from a rear D44 in my front? I'd imagine it's a bit iffy, D44 has been in so many vehicles over so many years with a lot of variations.
I knew people said it was a weak link in these trucks when shooting for power/big tires, but are they really so bad they can't handle a spool in some mud or over some rocks? It's not like I'll be spinning them at 80MPH down the highway. You know, I should be straight.. the tires on my truck now are street tires, I have some low tread (less than half) MTs I'm going to put on but I'm not going to have great traction anyways. If and when I ever upgrade my tires I'll go with a selectible (or LS) in the front, regearing and a selectible in the rear.
I'm going to keep an eye out for a LS but I wouldn't even begin to know where to find a used one.. of course, if front/rear are the same I should have no issue finding one from some Jeep guy
__________________
  #10 (permalink)
Old 04-21-2008, 03:52 PM
seriously, i think you'll be fine! i think sometimes we get so caught up in overkill we tend to overlook what a Dana 44 can actually do. I beat the hell outta my D50 front ttb with a 460, 35, and a very heavy foot and did not have the first issue! i say go ahead and lock it for now but be in the market for a D60. just run it till it breaks!
-cutts-
__________________
  #11 (permalink)
Old 04-21-2008, 04:56 PM
MBBFord's Avatar
MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold MBBFord is a splendid one to behold
I don't think there'd be a problem either.
Lock one hub and your good to turn all you want. When you know there's going to be something bad/challenging then lock the other hub.
Since you'd probably only be running 33s, I'd say go for it.
But, a good limited slip would work a little better and it wouldn't be as stressful, but then you'd have to reset your gears over just welding the spiders.
x3 on a D60 after/if you break the D44
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #12 (permalink)
Old 04-21-2008, 05:18 PM
Ford150/428/dud's Avatar
Ford150/428/dud is starting off with a positive reputation.
You should be fine you may or may not have any problems, just dont get supprised when you break something.
  #13 (permalink)
Old 04-21-2008, 05:31 PM
quadzjr's Avatar
the point is to build a rig not to break, why use something to greatly increase the chance to break your shafts.......unless you already plan to put a d60 it make absolutely zero sense to build the d44 when you will enevitably(sp?) be upgrading to a d60 anyways......
if you plan on keeping the d44, DO NOT weld it, a locker would be the max but a good LS is just fine......
i put a auburn L.S. in a d44 for a buddy of mine and his has worked out great.....542082 - Auburn Gear - Auburn Pro Series Limited Slip For 1971 & Up 30 Spline Dana 44 w/o C Clips | Tellico 4x4
__________________
Nick
: Sergeant at Arms
  #14 (permalink)
Old 04-21-2008, 05:38 PM
MBBFord's Avatar
What's to build...? Weld the spider gears and you're done.
__________________
  #15 (permalink)
Old 04-21-2008, 05:40 PM
quadzjr's Avatar
he'll be building it when he shatters some axles.....
if you dont mind breaking a few axles here and there, then go for it......IMO, that would suck, that combined with the chit azz turning off road, that would suck.........
__________________
Nick
: Sergeant at Arms
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
