Go Back   Ford Truck Enthusiasts Forums > Other Fords > 1968 - Present Full Size Vans
Register - Join us, its Free! FAQ Members List Timeslips Calendar Search Today's Posts Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 04-20-2008, 08:52 PM
Humam1953 is starting off with a positive reputation.
E350 fuel pump problem
My 1989 E350 motorhome with a 450 engine won't start up after the winter. The high pressure fuel pump on the frame does not get any power, while the fuel pump relay under the hood works and connects 12 V. The emergency switch inside on the passenger side seems to be ok (I tried to short it, too, with no results). Of course I have a spark and also checked all fuses. Carefully disconnecting the fuel line at the pump after my many tries does not show any residual pressure in the line.
Any help is appreciated. What else can be controlling the power supply to the pump?
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
