I've got a 1993 f150 4x4 with an e40d. the 302 is bored out to 332 i'm wondering what the best stroker kit for it would be? also looking for a cam and lifter kit, i know a lot less then i should about this kind of thing, any help appreciated.
The block can't be bored out to 332 cubic inches.. that's not physically possible to achieve with the stock crankshaft and rods. Maybe you meant it's bored 30 over?
Things get expensive when you go beyond the capacity of the stock computer and fuel system. The good news is it will handle 300hp give or take, and it doesn't matter too much how you get it as long as you keep the computer happy. Is the truck mass air or SD? If mass air you have loads of options, if not then they are fewer but still plentiful.
You can start by upgrading the cam to something ike the Crane 444211, you don't need lifters because your motor has roller lifters and these are OK to reuse, but you should get the matching valve springs.
