Quote:
Originally Posted by David85
So basically its shifting really soft at full power, correct?
You can get banks trans command that electronically raises the line pressure, but I don't think thats a very good idea compared to making the changes in the valve body.
No, It shifts really hard witch it just seems to float around at 3300 rpm for awaile before "banging" in the next gear at full throttle. As for the Banks trans command, It came with the sidewinder kit. It was the first thing I put on 3 months ago and it did make it shift harder at full throttle even without the turbo. As for the shift kit, If I go that route I will just get a built up tranny and torque converter. Im sure this tranny has been in here a long time or its stock so it probably wouldn't hurt anyway.
I will try to readjust the fipl and see what happens. You said try not to make it shift too soon, is 2800 to 3000 rpm too soon of a shift because thats where I would like it to be?
Thanks for the input.
